ADC
Prakruthi
Could anybody tell me the best way to output the digital words from
the ADC on to the hyperterminal. I seem to facing some problems with
printf. Any other way?
Thanks and regards,
Prakruthi
martin griffith
Thanks and regards,
Prakruthi
1) how are you interfacing the ADC to hyperterminal
2) what ADC is it?
3) Most people say hyperterminal is not very good
martin
Thanks and regards,
Prakruthi
Use serial communication. Got a serout routine?
Donald
Thanks and regards,
Prakruthi
Prakruthi,
Are you a first year engineering student ?
By your second year you should be able to do all the things you have
asked about on your own.
Please do some of your own homework.
To help you out, go here: http://jfgi.us/
donald
Prakruthi
2) what ADC is it?
martin
Hi Martin,
I m interfacing the ADC to the hyperterminal thru a USB using the
ATMega8 microcontroller
I m using the AD7714
The problem is that sometimes I dont see all three bytes of the digital
word on the output.Its a little strange. But I dont know if the problem
is with the printf only.
Regards,
Prakruthi
Rich Grise
One possible way to check this is to temporarily not use printf(), but
to format your own data and output it character by character with, say,
putc(), or putch(), or whichever - you could look it up.
Good Luck!
Rich
jasen
Hi Martin,
what printf format string are you using?, what do you see?
Prakruthi
@Jasen,
I m using %d to print an unsigned char data. I m looking to see a
digital word 3 bytes long. But sometimes I dont see all the three bytes
, I fail to see where they disappear.
Regards,
Prakruthi
Prakruthi
Good Luck!
Rich
@Rich,
Thanks Rich, Will try that out.Hope that helps.
Thanks again.
Regards,
Prakruthi
Roger Hamlett
Prakruthi said:
@Jasen,
Er. If the value is below 100, then %d, will only give two digits. If it
is below 10, %d, will only give one. You need to use %03d, which will give
a three digit field, with leading zeros, to ensure that you actually get
three digits each time.
Best Wishes
Arlet
Best Wishes
Correct, but even then the results aren't really easy to read.
If the 3 bytes from the ADC are in "h", "m" and "l", first convert them
into a 'long' type:
long val = ((long) h << 16) + ((long) m << 8) + (long) l;
and then print this value with printf( "%ld", val );
Or, if you insist on seeing the individual bytes for easier
verification with bit patterns on scope, use something like "%02x",
which prints each byte in 2 digit hex.
Prakruthi
Best Wishes
Thanks for the input Roger. Will try what you suggested. Hope it
works:) Thanks again.
Regards,
Prakruthi
Prakruthi
into a 'long' type:
Hi Arlet,
What you say makes a lot of sense. Thanks for the suggestion. Will try
this and keep you posted on the results.
Regards,
Prakruthi
