AM electromagnetic waves: 20 KHz modulation frequency on an astronomically-low carrier frequency
K
Keith Dysart
Quite counter intuitive, I agree, but none-the-less true.
To convince myself, I once created an Excel spreadsheet
to demonstrate the fact.
It along with some other discussion and plots are available
here http://keith.dysart.googlepages.com/radio5
To get exactly the same results, if, at time t0, the phases
for the signals being multiplied together are 0, then at
time t0, the initial phases for the signals being added
must be 90 and -90.
....Keith
John Fields
must be 90 and -90.
I
isw
After you get done talking about modulation and sidebands, somebody
might want to take a stab at explaining why, if you tune a receiver to
the second harmonic (or any other harmonic) of a modulated carrier (AM
or FM; makes no difference), the audio comes out sounding exactly as it
does if you tune to the fundamental? That is, while the second harmonic
of the carrier is twice the frequency of the fundamental, the sidebands
of the second harmonic are *not* located at twice the frequencies of the
sidebands of the fundamental, but rather precisely as far from the
second harmonic of the carrier as they are from the fundamental.
Isaac
Brenda Ann
Isaac
I can't speak to second harmonics of a received signal, though I can't think
why they would be any different than an internal signal.. but:
When you frequency multiply and FM signal in a transmitter (As used to be
done on most FM transmitters in the days before PLL came along), you not
only multiplied the extant frequency, but the modulation swing as well. i.e.
if you start with a 1 MHz FM modualated crystal oscillator, and manage to
get 500 Hz swing from the crystal (using this only as a simple example),
then if you double that signal's carrier frequency, you also double the FM
swing to 1 KHz. Tripling it from there would give you a 6 MHz carrier with a
3 KHz swing, and so on.
I
Ian Jackson
For multiplying FM, yes, of course, this is exactly what happens. And as
it happens for FM, it must also happen for AM.
However, I feel that the subject of the effects of harmonics of an AM
signal needs to be investigated. I think what you hear depends on how
and where the harmonic is produced, and the characteristics of the
receiver.
In the good old days of AM, on those occasions when I listened to the
2nd harmonic of my transmissions, I got the impression that the quality
of the audio was not very good, and that the mod depth was lower than on
the fundamental.
Assuming that the signal is coming from a 'normal' AM transmitter, you
could have two scenarios:
(a) In the first scenario, the signal is initially clean, but gets
multiplied by two, along with the sidebands. [This may occur in the
transmitter itself, or in the receiver, or in some external device.] In
this case, the frequencies and bandwidth of the sidebands will be
doubled (like FM multiplication). The signal should definitely be of
poor quality (it should sound rather 'toppy'), but may still be fairly
intelligible. If the bandwidth of the receiver is be insufficient to
embrace the full (doubled) bandwidth of the signal, you will only hear
the lower part of the audio spectrum. This will limit the toppiness, and
the level will be rather low, but, in practice, the signal quality may
be quite 'acceptable'.
(b) In the second scenario, the 2nd harmonic is effectively present
BEFORE modulation, so it gets modulated along with the fundamental. In
this case, the lower frequencies of sidebands of the 2nd harmonic will
be 'normal', and the signal will sound normal.
In practice, both (a) and (b) probably occur together (certainly in the
transmitter). Again, as the receiver will only select the lower part of
the audio spectrum, what you hear might sound OK. I suspect that, if you
'off-tune' a bit, you will find a lot of sideband 'splash' either side
of the signal.
It should not be difficult to set up a simulation of the above, and do
some quantitative tests. Any volunteers?
Ian.
Ron Baker, Pluralitas!
Keith Dysart said:
Ooops. I misspoke. They are not quite the same.
The spectrum is the same, but if you want to get exactly
the same result, the lower frequency needs a 90 degree
offset and the upper frequency needs a -90 degree offset.
And the amplitudes of the the sum and difference
frequencies need to be one half of the amplitude of
the frequencies being multiplied.
...Keith
You win. :)
When I conceived the problem I was thinking
cosines actually. In which case there are no
phase shifts to worry about in the result.
I also forgot the half amplitude factor.
While it might not be obvious, the two cases I
described are basically identical. And this
situation occurs in real life, i.e. in radio signals,
oceanography, and guitar tuning.
It follows from what is taught in high school
geometry.
cos(a) * cos(b) = 0.5 * (cos[a+b] + cos[a-b])
Basically: multiplying two sine waves is
the same as adding the (half amplitude)
sum and difference frequencies.
(For sines it is
sin(a) * sin(b) = 0.5 * (cos[a-b]-cos[a+b])
= 0.5 * (sin[a-b+90degrees] - sin[a+b+90degrees])
= 0.5 * (sin[a-b+90degrees] + sin[a+b-90degrees])
Don Bowey
...Keith
You win. :)
geometry.
No, they aren't the same at all, they only appear to be the same before
they are examined. The two sidebands will not have the correct phase
relationship.
One could, temporarily, mistake the added combination for a full carrier
with independent sidebands, however.
(For sines it is
I
isw
If you start with, say, a 1 MHz carrier AM modulated at 1 KHz, tuning to
the second harmonic gives you a 2 MHz carrier AM modulated at 1 KHz; not
2 KHz as your "must also happen for AM" would suggest.
Isaac
I
isw
Ron Baker said:
You win. :)
The beat you hear during guitar tuning is not modulation; there is no
non-linear process involved (i.e. no multiplication).
Isaac
Dave Platt
I believe that will be the likely scenario for any AM transmitter
which uses plate modulation or a similar "high level modulation"
system. If the RF finals are running in a single-ended configuration
(rather than push-pull) even the unmodulated carrier is likely to have
a significant amount of second-harmonic distortion in it... and I'd
think that this would tend to grow worse as the audio peaks push the
finals up towards their maximum output power.
Isaac
Whoa. I thought you were smoking something but
my curiosity is piqued.
I tried shortwave stations and heard no harmonics.
But that could be blamed on propagation.
There is an AM station here at 1.21 MHz that is s9+20dB.
Tuned to 2.42 MHz. Nothing. Generally the lowest
harmonics should be strongest. Then I remembered
that many types of non-linearity favor odd harmonics.
Tuned to 3.63 MHz. Holy harmonics, batman.
There it was and the modulation was not multiplied!
Voices sounded normal pitch. When music was
played the pitch was the same on the original and
the harmonic.
One clue is that the effect comes and goes rather
abruptly. It seems to switch in and out rather
than fade in an out. Maybe the coming and going
is from switching the audio material source?
This is strange. If a signal is multiplied then the sidebands
should be multiplied too.
Maybe the carrier generator is generating a
harmonic and the harmonic is also being modulated
with the normal audio in the modulator.
But then that signal would have to make it through
the power amp and the antenna. Possible, but
why would it come and go?
Strange.
Don Bowey said:
On 7/4/07 7:52 AM, in article [email protected],
"Ron
relationship.
What do you mean? What is the "correct"
relationship?
(For sines it is
Isaac
In short, the human auditory system is not linear.
It has a finite resolution bandwidth. It can't resolve
two tones separted by a few Hertz as two separate tones.
(But if they are separted by 100 Hz they can easily
be separated without hearing a beat.)
The same affect can be seen on a spectrum analyzer.
Give it two frequencies separated by 1 Hz. Set the
resolution bandwidth to 10 Hz. You'll see the peak
rise and fall at 1 Hz.
John Fields
That's not true.
The human ear has a logarithmic amplitude response and the beat note
(the difference frequency) is generated there. The sum frequency is
too, but when unison is achieved it'll be at precisely twice the
frequency of either fundamental and won't be noticed.
Don Bowey
"Ron
relationship.
relationship?
(For sines it is
When AM is correctly accomplished (a single voiceband signal is modulated
onto a carrier via a non-linear process), at an envelope detector the two
sidebands will be additive. But if you independe ntly place a carrier at
frequency ( c ), another carrier at ( c-1 khz) and another carrier at (c+ 1
kHz), the composite can look like an AM signal, but it is not, and only by
the most extreme luck will the sidebands be additive at the detector. They
would probably cycle between additive and subtractive since they have no
real relationship and were not the result of amplitude modulation.
craigm
1 kHz), the composite can look like an AM signal, but it is not, and only
by
They would probably cycle between additive and subtractive since they have
no real relationship and were not the result of amplitude modulation.
A peak detector is best understood in the time domain, try to create a
simple description in the frequency domain and you can only cause confusion
and incorrect conclusions.
Don Bowey
You appear to be confused. I established a set of conditions, which
necessarily describe
the frequencies a how they originate.
What domain is used for analysis is left to the reader. I can see the
results I described, equally in the two domains.
Or did I miss a point about your post?
craigm
At any point in time the value seen by a peak detector is the sum of all
individual frequency components. Some individual components will have
positive values, some negative, (a some may be 0). However, they all add.
Say one (only) adds while the other can add and subtract is misleading.
Don Bowey said:
"Ron
relationship.
relationship?
(For sines it is
The questions I posed were not about AM. The
subject could have been viewed as DSB but that
wasn't the specific intent either.
