I
isw
- Jan 1, 1970
- 0
John Fields said:That would suggest that there could be "low IM" instruments which would
be very difficult to tune, since they would produce undetectably small
beats;
Not at all. Since tuning is the act of comparing the acoustic
output of a musical instrument to a reference, the "IM" of the
instrument would be relatively unimportant, with a totally linear
device giving the best output. For tuning, anyway. Then, the
output of the instrument and the reference would be mixed, in the
ear, with zero beat indicating when the instrument's output matched
the reference.
in fact that does not happen. It would also suggest that it would
be difficult or impossible to create beats between two
very-low-distortion signal generators, which is also not the case.
That is precisely the case. Connect the outputs of two zero
distortion signal generators so they add, like this, in a perfect
opamp, (View in Courier)
| SG1 |---[R]--+----[R]---+--| POWER |--| SPEAKER |--| EAR |
+-----+ | | | AMP | +---------+ +-----+
| +V | +--------+
| SG2 |---[R]--+----|-\ | +----------+
+-----+ | >--+--| SPECTRUM |
+----|+/ | ANALYZER |
GND -V
and the spectrum analyzer will resolve the signals as two separate
spectral lines,
And when the two frequencies are very close to being equal, the spectrum
analyzer will only be able to resolve one frequency, and it will vary
between a maximum of amplitude and zero at a rate which is precisely
related to the difference between the two frequencies. If you get an
analyzer with finer resolution, I can always reduce the difference
frequency sufficiently to produce the described effect, which does not
in any way require a nonlinear process.
I understand your point and, while it may be true, the
incontrovertible fact remains that the ear is a non-linear detector
and will generate sidebands when it's presented with multiple
frequencies.
OK, but off subject. We were discussing whether a "zero beat" while
tuning an instrument requires a non-linear process (i.e. "real"
modulation. It does not.
What remains to be done then, is the determination of whether the
beat effect is due to heterodyning, or vector summation, or both.
Yup. And since the beat is easily observable using instrumentation of
measurably high linearity, whether or not ears have some IM is of no
matter. In fact, I agree that IM is produced in ears; just not at
significant levels for anything short of pathological SPL -- upwards of
120 dB, say.
Yes. The 180 degree situation is just a special case that very obviously
produces a change in output level in a linear environment. IOW it shows
that a linear combination of two nearly equal tones will cause a "beat"
in amplitude.
That's not true. Why do you think some harmonies sound better than
others? Because the heterodyning occurring at those frequencies
causes complementary sidebands to be generated which sound good, and
that happens at most SPL's because of the ear's nonlinear
characteristics.
For your argument to be true, there should be harmonies that can be
shown to "sound better" when played at a lower SPL (or better,
auditioned through a passive acoustical attenuator). Avoiding
pathological sound levels, I am not aware of any such thing ever being
demonstrated. Do you have any examples?
In fact, I believe it is the case that in "musical frequency space"
virtually every IM product of significance, regardless of where it
arises, is considered unpleasant.
And I still don't think you have adequately explained the things I was
referring to.
Do you have any references?
Isaac
