amp problem
omer_faruk
Oct 10, 2005
16
I have a home amp. and amp when open spekars than "tıs" goming sound
how that stop problem
help you
thanks
audioguru2
Apr 6, 2004
12,022
Hi Omer,
What is a "tis" goming sound?
Is it high frequency noise that sounds like and we call "hiss"?
If it goes away when you disconnect an input then the noise comes from the source that feeds that input.
If the hiss noise comes from the amp then is the amp a manufactured one or an amp you built yourself? Please post its schematic. ;D
kankundachi
Oct 15, 2005
8
Hi omer_faruk :
    As far as you said this problem,it is probability the noise to cause.Especially power circuit is clean output!? If it has 50~60Hz frequency,then it will cause this problem.You can check this point first. :)
Best Regards,
            Stanley
omer_faruk
Oct 10, 2005
16
yes i understand.i dont open music.but amp than "hiss" coming sound.
thanks
audioguru2
Apr 6, 2004
12,022
Does the hiss sound go away when you disconnect the input to the amp?
Was the amp good before and the hiss sound is a new problem?
Did you add new speakers with better or peaky tweeters?
Is the amp trying to whisper something to you? ;D
