Amps are big.
flippineck
Sep 8, 2013
358
Having spent an evening soldering 12 off, 20W 12V halogen lightbulbs together to create a 'dummy load' to simulate something behind a battery charger eating up the energy supplied by solar panels, I was quite suprised.
Rigged them up as six strings of two each series string, all connected in parrallel.
I expected that applying 24V from my new bench PSU, might result in a few amps flowing and an array of moderately lit bulbs.
As it was, the bulbs started lighting up at a pretty low volts level and by the time I'd cranked it up to 24V, I had nearly 10A flowing and the fixture I'd rigged up to hold the lamps was starting to go on fire.
The PSU's rated to happily supply 10A but I was starting to feel like I was in welding territory!
There's a lot more punch in an amp than I thought.
Well... Each bulb requires 20/12A = 5/3A = 1 2/3A, so each string will be 1.667A times 6 strings, that's 10A.
flippineck
Sep 8, 2013
358
Yes the maths should have been obvious to me I guess.. If there's 10A on offer then the bulbs will take it! Just pleased that my PSU survived the ordeal. Pity I've already left averagely good ebay feedback!
Next time I won't use a plywood frame-thing to hold the bulbs. What was I thinking..
This is the PSU in case anyone needs a recommendation for a really easy to use, rugged bench supply that seems capable of surviving abuse .. not the seller I used but same type
www.ebay.co.uk/itm/142045067116
