Analog Forced into Digital
Radium
What will happen if an sine-wave analog signal is forced into a
electrical device only meant for receiving digital signals?
Robert Baer
Depends on the amplitude of the sine wave, and hysteresis levels (if
any).
A few years ago (1980 to be a litle more accurate), the first IBM
PC/XT has a cassette port that was meant to use the Kansas City standard
for reading/writing binary data.
This is a specific case where an analog (audio) signal drove a digital
input; no hysteresis was used.
A nifty program was made so one could record voice and music to files,
and play them back.
One-bit audio!
Worked quite well, a lot better than one would expect.
Just make sure that the input is not over-driven; the positive swing
should be clamped to prevent it from going more positive than the supply
voltage of the digital IC that is being driven.
Most digital ICs already have clamping for negative signals.
Q
Quack
The 'digital device' will see a '1' or '0' when the analogue signal
rises above or falls below a curtain threshold. As far as i have seen,
this is usually about 1.5 to 2.0 volts. below which will be seen as a
'0', above a '1' (typically).
What are you trying to do ?
Alex.
Jerry Greenberg
Most likely it will not respond, or may output some noise if anything.
The digital circuit, depending on its design, should normaly mute if
it does not recognize the proper protocal structure, such as packet ID
data, parity, and the proper pulse train of data.
Jerry Greenberg
http://www.zoom-one.com
Dbowey
glucegen posted:
First it depends on what you mean by "device."
Do you mean, for example, a modem's digital port (equipment)?
Do you mean an IC designed for digital applications (component)?
An analog signal can drive some digital components, but the component must be
selected to be able to withstand a slow rising voltage. Components that can't
handle the slow rise-time will likely be damaged.
At best driving an analog signal into the digital port of some equipment will
do nothing, or at best result in garbage at the output. Or it could damage a
component in the equipment.
Don
Radium
How so?
I don't understand why a device strong enough to handle the roughness
of digital signals (discrete, square-wave, spikes) could not enjoy the
smoothness of analog signals (smoothly varying, sine-wave)
Dbowey
glucegen posted:
(Dbowey) wrote in message
How so?
With a slow rise time signal, the device can be in an indeterminate state
between 0 and 1 for too long, drawing excess current. Read component specs.
..>I don't understand why a device strong enough to handle the roughness
You are attempting to apply attributes to analog and digital that are not
realistic. There is nothing "rough" about digital signals.
In analog, not all signals are sine-waves.
Don
Robert Baer
Alex.
*If* the input is TTL, then the threshold is 1.4V and varies according
to temperature (roughly -4.4mV/C).
CMOS input thresholds are about half of the supply voltage *if* no
hysteresis; i do not know what theye might be if it is a schmitt input.
