Analog voltmeter question - minus DC voltage
Dust bunny
Oct 4, 2012
10
I need an analog panel mount voltmeter that can show a minus DC voltage range of approximately -500mV to -1500mV
I read however, that an analog voltmeter cannot display minus values. Is that correct?
If it is, can I just reverse the polarity of the connections to a say, 2 volt voltmeter?
Many thanks!
Jotto
Aug 24, 2012
120
I have a meter that can read both positive and negative without changing anything. So I would think there are other meters that can do the same thing, you will need to search it out.
I am talking a analog meter, not a digital. You should be able to get a digital one also.
14,293
Google "voltmeter center zero" (without quotes) or go here.
Reversing the leads will be okay as long as the meter has no other connection to the circuit.
