Angle of view on minidome cameras
Hi all,
What sort of angle of view do you get with mini dome cameras (4 inch
or 6 inch dome). For example if I mount a dome 8ft high at the end of
a 100ft hallway, will I be able to adjust the camera high enough to
see the whole hallway. I 'm not concerning with focal lenght or
anything, but how far in degrees can these things be turned from a
vertical, or straight down position?
Thanks in advance,
mister g
every mini dome i've used - you pretty well get 180 degrees of view in every
plane
mechanically the "camera" is mounted on a universal joint arrangement within
the housing giving full range of movement
F
fly in the ointment
You will be able to adjust the camera to see the hallway. Since the hallway
is 100 feet long though, you might want to consider a longer lens than the
ones (4mm) typically supplied with mini domes.
js
