Dave D
- Jan 1, 1970
- 0
Sam Goldwasser said:Let the flame wars begin... NOW! ;-)
No war from me, I agree totally!
Let's take a survey.... How many of the professional techs,
engineers, and scientists who read this group actually do
periodic cleaning of inside of their monitors and TVs?
If you're obsessive-compulsive and have nothing better to do, by
all means clean the insides of your CRT equipment. But it's
probably more likely that something will get messed
accidentally, than any significant improvement in either
performance or life span.
The high voltage area of modern CRT equipment is generally
enclosed and or sealed with HV grease or adhesive. It's not
like old all-tube-type TVs where everything collected an inch of
dust if you turned your back.
Yes, dust does collect. And yes in principle that may affect
something eventually. But if there are no symptoms, leave it
alone. It's not likely that a gradually degradation in
performance is dust related. My approach about these things is
that "if it ain't broke, don't fix it".Seriously, if you're
in a dusty dirty shop floor, then there may be some benefit.
But if it's a home or office environment, don't you have better
things to worry about than to clean the insides of your 34,153
electronic gadgets????
For the record, I do not clean inside electronic equipment
unless there is a reason to go inside. My TV is 26 years old
and I've repaired it twice over that span due to defective
chokes (probably a parts problem from the supplier at the time
of manufacture). Other TVs in the house are all more than 15
years old and except one set of cracked solder joints, havne't
needed repair since I acquired them. I generally keep computer
monitors for 8 or 10 years without problems.
Sammy said:Have you actually cleaned inside one of your monitors/TV in order to
see how noticeable (or not) the change in picture quality is?
I've cleaned a lot of them, but never for the sole
purpose of seeing if it affects picture quality.
It does not.
I (semi)regularly clean the insides of my desktop computers. OpeningRoy said:Sure it does. The collection of dust, and much of that moistened at
some point makes for a leaky anode supply and feed wire at the very
least. That makes for poor or shifted focus settings, and other
problems that less than your average video afficianado won't notice.
up, reseating all boards and connectors is a good thing, IMO. In fact,
this particular computer had started having 'symptoms' a month or two ago.
I performed the above, and everything was set right again. There was a
lot of dust on the fans and quite a bit had caked up inside the power
supply (yes, I even opened up the ps).
I won't wait so long the next time....
But, no; to answer your question, I rarely clean the inside of my
monitors (unless I have to get inside to address some issue).
jak
Thank you - I stand corrected.
Roy L. Fuchs said:Most folks rarely notice their focus shifting as well. One has to be
video oriented to notice such things.
This is why I bought the one monitor in the world I could find that
has the highest video bandwidth out there at 185Mhz (now the bastards
are up to 210MHz!). Nice, tight, crisp and clean, CRTs are STILL the
king!
