Anyone uses Rabbit RCM?
  • Thread starter Marco Trapanese
  • Start date
Marco Trapanese
I have a problem with an RCM4100 and DC 10.21.
Perhaps someone could help me.
I can't handle the Timer C interrupt correctly. The code below will hang
the CPU at power-up.
The examples provided from Rabbit (located in the Sample folder od
Dynamic C) work fine so I guess the problem is in my config lib (see
below too).
Any idea to find out the problem?
Thanks in advance
Marco / iw2nzm
#class auto
#use "UND_CORE_BOARD.LIB"
#define led_red_toggle() BitWrPortI(PBDR, &PBDRShadow,
!BitRdPortI(PBDR, 7), 7);
nodebug root interrupt void timerC_isr() {
led_red_toggle();
void main() {
UND_BoardInit();
SetVectIntern(TIMERC_OFS / 0x10, timerC_isr);
for (;;) {}
/*** BeginHeader */
#ifndef __UND_CORE_BOARD_LIB
#define __UND_CORE_BOARD_LIB
/*** EndHeader */
/* START LIBRARY DESCRIPTION
UND_CORE_BOARD.LIB
DESCRIPTION:
This library was generated by the Rabbit 4000 I/O LIB Utility.
If it is modified in any incorrect way it might not load properly.
Usage:
main()
UND_BoardInit();
SUPPORT LIBRARIES: none
END DESCRIPTION
/*** BeginHeader UND_BoardInit */
void UND_BoardInit();
void ClockCheck();
void SetupSerial();
#define CINBUFSIZE 31
#define COUTBUFSIZE 31
#define SERC_TXPORT PCDR
#define CDRIVE_TXD 2
#define SERC_RXPORT PCDR
#define CDRIVE_RXD 3
#define DINBUFSIZE 511
#define DOUTBUFSIZE 511
#define SERD_TXPORT PCDR
#define DDRIVE_TXD 0
#define SERD_RXPORT PCDR
#define DDRIVE_RXD 1
#define EINBUFSIZE 127
#define EOUTBUFSIZE 63
#define SERE_TXPORT PEDR
#define EDRIVE_TXD 6
#define SERE_RXPORT PEDR
#define EDRIVE_RXD 7
#define FINBUFSIZE 31
#define FOUTBUFSIZE 31
#define SERF_TXPORT PEDR
#define FDRIVE_TXD 2
#define SERF_RXPORT PEDR
#define FDRIVE_RXD 3
/*** EndHeader */
/* START FUNCTION DESCRIPTION
UND_BoardInit <UND_CORE_BOARD.LIB>
END DESCRIPTION
void ClockCheck()
if (freq_divider != 96) // 29.49 MHz, doubled
exception(-ERR_LIBCLOCKSPEED);
void SetupSerial()
serCopen(1200L);
serDopen(115200L);
WrPortI(SDCR,&SDCRShadow, 0x03);
serEopen(19200L);
WrPortI(SECR,&SECRShadow, 0x21);
serFopen(19200L);
WrPortI(SFCR,&SFCRShadow, 0x21);
ClockCheck();
// The following differ from BIOS settings
SetupSerial();
WrPortI(I0CR,&I0CRShadow,0x03); // Port E Input and output Pins
WrPortI(ICS1R,&ICS1RShadow,0x33); // IC Channel 1
WrPortI(ICT1R,&ICT1RShadow,0x42); // Port C Input and output Pins
WrPortI(PBDDR,&PBDDRShadow,0xFF); // Port B Input and output Pins
WrPortI(PCAHR,&PCAHRShadow,0xC0); // Port C Input and output Pins
WrPortI(PCFR,&PCFRShadow,0x15); // Port C Input and output Pins
WrPortI(PEAHR,&PEAHRShadow,0x30); // Port E Input and output Pins
WrPortI(PEALR,&PEALRShadow,0x30); // Port E Input and output Pins
WrPortI(PEDDR,&PEDDRShadow,0x44); // Port E Input and output Pins
WrPortI(PEFR,&PEFRShadow,0x44); // Port E Input and output Pins
WrPortI(QDCR,&QDCRShadow,0x08); // Port E Input and output Pins
WrPortI(SBDHR,NULL, 0x81); // Serial Port B
WrPortI(SBDLR,NULL, 0xFF); // Serial Port B
WrPortI(TAT1R,&TAT1RShadow,0x02); // Timer A
WrPortI(TCCR,&TCCRShadow,0x09); // Timer C
WrPortI(TCCSR,&TCCSRShadow,0x01); // Timer C
WrPortI(TCDHR,NULL, 0x8F); // Timer C
WrPortI(TCDLR,NULL, 0xBE); // Timer C
// The following are used by the configuration utility
// Restore(SBCR, 0x0D) // Serial Port B
// Restore(SCCR, 0x01) // Serial Port C
// Restore(SCDHR, 0x8B) // Serial Port C
// Restore(SCDLR, 0xFF) // Serial Port C
// Restore(SDCR, 0x03) // Serial Port D
// Restore(SDDLR, 0x1F) // Serial Port D
// Restore(SECR, 0x21) // Serial Port E
// Restore(SEDLR, 0xBF) // Serial Port E
// Restore(SFCR, 0x21) // Serial Port F
// Restore(SFDLR, 0xBF) // Serial Port F
// Restore(APIC, 0x01) // Serial Port C
// Restore(APID, 0x01) // Serial Port D
// Restore(APIE, 0x01) // Serial Port E
// Restore(APIF, 0x01) // Serial Port F
// Restore(DBL, 0x01) // Processor Options
// Restore(DINBF, 0x1FF) // Serial Port D
// Restore(DOUTBF, 0x1FF) // Serial Port D
// Restore(EINBF, 0x7F) // Serial Port E
// Restore(EOUTBF, 0x3F) // Serial Port E
// Restore(USEPC, 0x01) // Serial Port C
// Restore(USEPD, 0x01) // Serial Port D
// Restore(USEPE, 0x01) // Serial Port E
// Restore(USEPF, 0x01) // Serial Port F
/*** BeginHeader */
#endif
/*** EndHeader */
//checksum:F314
