Anyone with experience using ssh on Raspberry Pi Model B
I am having very irritating problems
using ssh from Fedora 15 box to a
Raspberry Pi Model B board, running
OpenELEC 2.99.5. It appears that the
ssh client can connect with the ssh
server on the Raspberry Pi, but
authentication fails. If anyone has
used this board, and has experience
successfully using ssh to the board,
I would like to contact you.
Jasen Betts
I have never had any problems with that.
Have you got "ssh -v" output to support
your hypothesis.
Andrew Holme
SSH from PuTTY on Windows 7 to Raspbian on Raspberry Pi works for me.
The following is the output for a typical
session between the Fedora box and Raspberry
Pi.
ssh [email protected] -vvv
OpenSSH_5.5p1, OpenSSL 1.0.0e-fips 6 Sep 2011
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.1.2 [192.168.1.2] port 22.
debug1: Connection established.
debug1: identity file /home/lama/.ssh/id_rsa type -1
debug1: identity file /home/lama/.ssh/id_rsa-cert type -1
debug3: Not a RSA1 key file /home/lama/.ssh/id_dsa.
debug2: key_type_from_name: unknown key type '-----BEGIN'
debug3: key_read: missing keytype
debug2: key_type_from_name: unknown key type 'Proc-Type:'
debug2: key_type_from_name: unknown key type 'DEK-Info:'
debug3: key_read: missing whitespace
debug2: key_type_from_name: unknown key type '-----END'
debug1: identity file /home/lama/.ssh/id_dsa type 2
debug1: identity file /home/lama/.ssh/id_dsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.5
debug1: match: OpenSSH_5.5 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.5
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: [email protected],[email protected],ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,[email protected]
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,[email protected],hmac-ripemd160,[email protected],hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,[email protected],zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 124/256
debug2: bits set: 513/1024
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: host 192.168.1.2 filename /home/lama/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 1
debug1: Host '192.168.1.2' is known and matches the RSA host key.
debug1: Found key in /home/lama/.ssh/known_hosts:1
debug2: bits set: 567/1024
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/lama/.ssh/id_dsa (0x1996038)
debug2: key: /home/lama/.ssh/id_rsa ((nil))
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/lama/.ssh/id_dsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /home/lama/.ssh/id_rsa
debug3: no such identity: /home/lama/.ssh/id_rsa
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
[email protected]'s password:
debug3: packet_send2: adding 64 (len 57 padlen 7 extra_pad 64)
debug2: we sent a password packet, wait for reply
Permission denied, please try again.
debug1: No more authentication methods to try.
Permission denied (publickey,password).
Mikko Syrjalahti
Check what is in your ssh key file.
My .ssh/id_rsa contains something like this:
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,0000000000000000
0sd33kK324234k....
Can you log in using username+password ?
0sd33kK324234k....
In my case, both the Fedora box and the Raspberry
Pi are using OpenSSH 2 version 5.5. I have used
ssh-keygen several times to generate keys for
RSA, RSA 1 and DSA and even edited my /etc/host.allow
by adding sshd : ALL. My RSA private key starts as
MIICXgIBAAKBgQDBEDwKIQ3gPGXxQUc9HMAaGetKRjI5TG66CogTAufyfgHOMeC
e
Yes I have tried username/password but I have had no
luck.
