Arduino Nano built in RGB LEDs won't turn off
KennyIII65
May 24, 2026
12
Newbie here.. Trying to get used to using IO on my Nano.
I can get the Orange LED to turn on and off, but the RGB LEDs will not shut off using digitalWrite(LED2, LOW);
Probably an easy answer...
Thanks in advance...
Kenny
bertus
3,877
I only see four leds on the nano marked tx , rx , on and l.
I see no rgb led.
Post a schematic of the used setup.
What kind of rgb led are you using?
Is it a bare led or has it a controller build in?
Bertus
KennyIII65
May 24, 2026
12
Here is a markup of the schematic. LEDs circled are mounted on the Nano...
danadak
Feb 19, 2021
1,104
What does schamtic look like from pin to LED and its power source ?
KennyIII65
May 24, 2026
12
I guess what might help is that I can't find the header files that define the values in cpp for the Arduino hardware. For instance,
I defined LED2 = 14; Actually I used an array... int leds[] = { LED_BUILTIN, 14, 15, 16 };
Where is LOW defined? Where is LED_BUILTIN defined? Anybody have a directory for me?
Kenny
Martaine2005
May 12, 2015
5,318
What Nano have you got?
The 33BLE is active low, meaning they’re on. High turns the LED off.
bertus
3,877
That is not a standard arduino nano.
It shows an arduino nano esp32.
Bertus
KennyIII65
May 24, 2026
12
Well, after doing some more testing, I find if I turn on, say, the Blue LED and then turn it off, there is a background light of white(?) that stays on. Possibly for brightness? That is the light that doesn't turn off.... IDK...
KennyIII65
May 24, 2026
12
Did you read my link?.
It has a sketch.
I did.... Thanks...
Here's Mine...
Hook yo WiFi & Blinky
#include <WiFi.h>
const char* ssid = "WiFi Surveillance Van"; // Change this to your WiFi SSID
const char* password = "KeepOffMyLan"; // Change this to your WiFi password
int i = 0;
void setup() {
// put your setup code here, to run once:
for (int p : leds) pinMode(p, OUTPUT);
digitalWrite(leds, HIGH); // LED Orange ON
delay(1000); // chill for 1 sec.
Serial.begin(115200);
while(!Serial){delay(100);}
// We start by connecting to a WiFi network
Serial.println();
Serial.println("******************************************************");
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
digitalWrite(leds, LOW); // turn Orange LED off (LOW is the voltage level)
Serial.println(" ->");
void loop() {
// put your main code here, to run repeatedly:
for (int p : leds) digitalWrite(p, LOW);
// next LED
i = (i + 1) % 4;
delay(1000);
// turn next on
Serial.println(i);
delay(2000);
KennyIII65
May 24, 2026
12
I did.... Thanks...
Here's Mine...
#include <WiFi.h>
int i = 0;
void setup() {
Serial.println();
delay(500);
Serial.print(".");
void loop() {
// next LED
i = (i + 1) % 4;
delay(1000);
// turn next on
Serial.println(i);
delay(2000);
That copy & paste dropped my indexes... A few missing..... ahh... Forum italicizing.....
danadak
Feb 19, 2021
1,104
Also be aware modern LEDs even with uA current in them will glow. So depending
on drive circuit one can have this problem.
In your case you only have leakage so should be OK on this.
KennyIII65
May 24, 2026
12
OK. I finally actually read the comments in detail and my issue is the LED_BUILTIN is active HIGH and the RGB LEDs are active LOW. The White is all on. Mystery solved....
Thanks all!
Kenny
