are BT2222 transistors the same as 2N2222
flippityflop1
Jan 27, 2009
135
are these NPN BJTs:
http://pdf1.alldatasheet.com/datasheet-pdf/view/17918/PHILIPS/MMBT2222A.html
the same as those 2N2222 that has been around for since forever? can i trust that the reverse active and avalanche breakdown profiles are the same??
audioguru2
Apr 6, 2004
12,022
A transistor is slowly damaged when operating with avalanche breakdown of a reverse-biased emitter-base junction.
The 2N2222 and BT2222 are guaranteed to withstand a reverse emitter-base voltage of 6V or less.
Both transistors probably have the same chip but since the BT2222 is in a tiny case then it will overheat even with a very low power dissipation.
