Germanium power transistors
keravon
Mar 16, 2022
Hi All,
I'm trying to find equivalents for AD 149 DE8 N and AD 149 DE3 N Germanium power transistors. Or are they the same transistor?
I am restoring an old GEM organ which has these in the power supply section. As far as i can see they are not functioning.
Thanks for your help.
K
kellys_eye
Jun 25, 2010
6,512
I'm not familiar with the sub-numbering system you refer to but such differences are usually related to the gain of the device. If it's used in a power supply (series regulator) then gain isn't an issue so either device would work. Double check that the differences aren't down to pin out arrangements - but that's easily averted by direct wiring.
bertus
3,877
The sub-numbering could have to do with production location and production date.
It will be of no influence on the working of the transistors.
Bertus
