Mark
- Jan 1, 1970
- 0
Is a dual/quad compartor in the same DIP totally indepentant of each other
or is there some interaction between the outputs?
Mark said:Is a dual/quad compartor in the same DIP totally indepentant of each other
of each other or is there some interaction between the outputs?
The LM392 (dual-function opamp + comparator) has a spec called
"Amplifier-to-Amplifier Coupling," (f = 1 kHz to 20 kHz), which
is −100 dB typical (input referred). And their LM324 quad
opamp data sheet spec is −120dB typ.
Assuming a 12V output swing, a -100dB spec would imply a 120uV
input feedthrough effect. In addition to external-component
stray capacitance, one should watch out for power-supply-rail
feedthrough. The LM324 opamps have a 100dB typical power-supply
rejection ration spec. The opamp's input circuit is similar to
the LM339 comparator and we can expect it has a similar weakness.
So care should be taken that current switched by the comparator's
output doesn't cause too much pin 12 supply-rail noise.
Mark
