Are multiple amplifier stages better than one ???
I have a few questions about the design of the circuit in Figure 1
page 71 located at https://ilocker.bsu.edu/users/jalbers/WORLD_SHARED/WireTracer.PDF
The gain of the first op amp stage is 10 and the gain fo the second op
amp stage is 33 for a total net gain of 330. Why not just use one op
amp and set the gain to 330?
When designing a circuit like this, why use a low gain of 330, why not
a higher value? How did the author arrive at 300?
Is it better to have multiple stages in an amplifier rather than just
using one op amp to get the job done? If so, why?
Any help would be greatly appreciated. Thanks
Michael Black
One big reason for using multiple stages is because one stage won't
provide enough gain.
Don't be misled by the op-amps, think of all the stages inside those
op-amps that are needed to provide the gain. Before op-amps, and
even today, discrete components would require multiple stages to get
enough gain, precisely because a single stage couldn't.
Remember, an op-amp may be able to supply a lot of gain, but it
comes at the cost of bandwidth. The higher the gain, the lower the
bandwidth (though in more recent times the gain-bandwidth has improved
significantly from the days of the 1MHz 741, so you can get more gain
at a higher frequency than back then). So if the op-amp has a 1MHz
gain-bandwidth, divide that 1MHz by the gain and you'll see how
performance tops off. A gain of ten would allow flat response to
100KHz, a gain of 33 would allow a flat response to 30KHz, and a gain
of 330 would allow a flat response to 3KHz. That latter may really
impact things if you hope for good audio response.
Another reason for multiple stages is so the stages can be optimized
for their place in the chain. A first stage may be optimized for
low noise, especially if the input signal is very weak, like a radio
signal or the audio coming out of a phono cartridge. You want
to get the signal level up to a decent level without adding much noise
because otherwise that noise will be amplified along with the desired
signal.
Or, an output stage may be optimized for driving a speaker or something,
so it's more important than it can supply current gain rather than voltage
gain.
As for the amount of gain, surely whoever put it together decided
on the gain because that was what's needed. The circuit must
have some purpose, and thus the design specs specify the gain needed.
Michael
Bob Eld
There is no reason this circuit would not operate perfectly well with a
single op-amp with a gain of 330 times. The discussion about gain bandwidth
product, while true, is a nonsequitur in this application. There is
sufficient gain-bandwidth to amplify mid range audio signals for your
purposes.
However, high gain implies a wide spread of resistance values. Finding a
suitable gain control pot might be an issue.
This thing has a low frequency cutoff of 1590Hz. What frequencies is it
supposed to amplify? It would be very poor at 50 or 60 Hz.
One poster mentioned DC characteristics such as drift and offset as a reason
for keeping the gain low per stage, but this circuit has a DC gain of unity
in both stages. A single stage version would be the same, meaning the DC
characteristics are immaterial.
Someone also mentioned noise. The more stages and the more TOTAL gain the
more noise. Spreading the gain amongst more stage adds noise it does not
reduce it. The total gain is the same.
These guys used two amplifiers because they felt like it not because of any
technical reason. They had a dual amplifier so that's what they used. A
better circuit would use one amplifier to establish the battery center
voltage with high resistance and the other amplifier as a single gain stage.
In this way the battery drain could be minimized to microamps in the quiet
state.
Jamie
Capacitance is designed in OP-AMPS in the feed back especially
, to help eliminate oscillation that would occurs.
In many references, this is called the Miller effect. some may
look at it a slightly different way.. Which is why, even though
comparator will work for basic OP-AMPS, they normally do not have
this kind of prevention circuit designed into them and can oscillate but
allows for a fast switching time to take place over using an
Op-amp as a comparator as long as the proper hysteresis is engineered
into it.
(Back to Op-amps).
This is when the Band Width comes into play, having a high gain
stage would involve using high value ratio&resistor networks and thus
the capacitance in the OP-AMP would have adverse affects on the gain at
higher frequencies.
Using much lower value resistors and still trying to get the gain
from a single stage then places the OP-amp into a stress state, if you
want to look at it that way.
Normally to get high gain and low noise, you select a practical
resistor network that will not allow the capacitance to place your band
width out of spec and keep the Op-amp in safe operating range.
Thus, multiple stages are created to smoothly bring it up.
You'll also find this kind of normanclature in basic transistor design
also.
http://webpages.charter.net/jamie_5"
Eeyore
Bob said:
The main reason for separate stages has to do with
an op-amp parameter called Gain Bandwidth Product.
The available gain of the chip falls with
frequency, so if you need a wide bandwidth you
must use a lower gain.
Yes, but for best noise performance the first stage should have the higher gain (making
certain assumptions about source impedance and op-amps used but almost invariably the
case).
Graham
Eeyore
Not to mention that with essentially no feedback, the distortion is likely to be quite
high.
Graham
Eeyore
purposes.
state.
In this particular application, it looks like you're quite right.
Graham
Phil Allison
"Eeysore"
gain (making
invariably the
case).
** Nonsense.
Once the first stage has a gain of a few times, then its ouput noise will
swamp the input noise of the following stage - no matter what gain it has.
...... Phil
Eeyore
Phil said:
"Eeysore"
** Nonsense.
** Nonsence.
What I say is true at ALL times. It's simple math.
Graham
Phil Allison
"Eeysore"
** Nonsence.
** Nope - it is just more of your inexhaustible supply
of RIDICULOUS & FALSE INFORMATION !
...... Phil
"Eeysore"
.....    Phil- Hide quoted text -
- Show quoted text -
the more stages just amplafies your thermal distortion and passes it
to the next stage and thats not an effeicient way and you end up with
much more distortion over all
Bill
Man, you are a crack. I hope you are not trying to live off this.
Explain why you’re not passing distortion from your 4055 or any other
op amp and then amplifying that distortion in multiple stages.
I work for Yamaha Roland, fender and 5 other companies that make
amplifiers as a factory authorized repair tech I think I know
something about the first question that was purposed.
Be constructive and tell me why I am wrong maybe a explanation other
thanbtbant
Bill
thanbtbant
Non-technical: my apologies. I don't like what I wrote. Again, sorry.
Technical: if each of the stages has a bandwidth that includes the
audio bandwidth and a response that is sufficiently flat, which is the
usual case, the stages do not amplify the input distortion, because
distortion is a ratio, and each stage amplifies both wanted and
unwanted components in more or less equal amounts. Of course it will
slightly favor one or the others, but it is hard to tell which ones,
and the "average" of the "gain factor" applied to the input distortion
is closer to 1 than to G (the gain of that stage). Another thing is
that that stage will also create and add new distortion products.
Best,
Phil Allison
"Bill"
** Simply stated, the distortion (as a percentage) will not change - it
just gets amplified along with everything else that is presented to the
input.
Of course it will
** In a chain of audio op-amp stages, the one operating with the highest
output level will usually be the one producing the most non-linear
distortion. So that makes it the last one.
In practice however, the THD produced is so low it is negligible - even
using old types like the 301A or 741.
...... Phil
George Herold
"Eeysore"
**  Nonsense.
.....    Phil
Hmmm, Well this could depend on the resistor values choosen for the
second stage. A low noise front end coupled to a second stage with a
10k ohm resistor could make things worse.
George
George Herold
much more distortion over all- Hide quoted text -
What is thermal distortion?
George
Eeyore
John said:
Can't argue with that. ;-)
I've got an old Radio Shack stereo receiver which lost a 1458 early on
and, after replacing it, it still works and I can still jam with Hot
Tuna.
It's a little different when working with sub -100dB THDs ! Not to meantion
500pV/sqrt Hz input devices.
Graham
Eeyore
Well spotted. I'm working on an ultra low noise differential input right now (no -
none of the IC solutions are good enough) and resistive noise is truly a PITA !
Never underestimate it, so many people do then wonder why their circuit's 'hissy'.
Graham
Eeyore
Certain devices when driving heavy loads can get quite warm (even ona cycle by
cycle basis). If the device is not designed to equalise this heat across specific
areas of the chip, it can affect the sensitive bits at the front end and lead to
thermally induced distortion.
I've even seen the effect in dummy load resistors with highish coeffs of temp. You
measure THD at the amp and it's fine (say 0.03%) and measure it at the load and
it's 0.1% ! The reason is the combination of the non-linearity of the load and the
finite resistance of the connecting wires.
Graham
