Good evening everyone,
I am little into the realm of electronics - but trying to use some simple pieces to make a few neat devices. With that said, I can put parts together and eventually figure things out, however I'd like to seek some assistance to make sure I am on the right track and also if I can improve what I am doing. Earlier the 9v I was using got very hot very fast, I don't think that is supposed to happen.
Anyways. I'd like the pizo to beep every time the lever hits the button. I've figured out already that I need the connections on the last two (jumpers?) to make that happen. If it's on the first and third then the pizo beeps until you click. I tried to google more information but either I'm not searching the correct terms or there isn't much I could find.
Am I hooking this up the correct way? Should the two black wires connect to eachother and then to nothing? If I were to add a switch (to turn the pizo off when I'm done) where would I put that and what type should I buy?
I would really appreciate any advice!
Thank you.
Thank you.
