AT PSU changeover to ATX PSU. Power button-buy one?
Darren
Hi
My spare PC is in an AT case. It's currently powered by a 200w AT power
supply.
The motherboard has AT and ATX connectors. The mobo is an Epox EP-58
MVP3C-M and has power connectors for both AT and ATX cases.
I'm taking out the generic AT 200w power supply as it's getting old and I
have a new 400w ATX power supply to put in.
The AT PSU has a power cord which runs to a button on the front of the case.
The ATX PSU does not have a power cord with a button attached to it.
I've noticed the mobo has a 2 pin connector labelled 'POWER-ON'.
After installing the new ATX PSU, is it a case of buying a power button with
two wires that go to the 2 pin 'POWER-ON' connector?
If so, I'm not sure which pin will be positive and which will be negative
and I'm not sure my mobo manual tells me...
I suppose that electronics shops would stock these buttons.
I'm from downunder, if that helps with PC component location advice.
Thanks heaps
Darren
Sam Goldwasser
As they say: "If it ain't broke, why fix it"?
What's wrong with an old supply if it does the job? Unless there are
problems, or you are seriously expanding it, a new power supply won't
make it run better. :)
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
Bob Urz
Darren said:
Hi
supply.
Thanks heaps
Darren
perhaps you can recycle the unused "Turbo" button......
James Sweet
Either way to answer the question, polarity doesn't matter for the
pushbutton, any momentary button will work, all it does is connect the two
wires together when you press it.
James Sweet
That would work except that usually that's a latching button, though the
latch mechanism may be removable. Could use the reset button as well but
then of course you lose the reset function.
Darren
Good idea bob. I'll look at that.
As far as replacing, fair comment Sam but the old one has no essential
functions for failure, overload etc and the new one has and was free.
Darren
Darren
I was hoping polarity wasn't an issue. Thanks very much.
K
Ken
Darren
Some MBs that accept either an AT or ATX PS have a jumper or switch
that must be set depending upon which type you use. You should check
your MB literature for such information.
jakdedert
the latch mechanism may be removable. Could use the reset button as
well but then of course you lose the reset function.
Yeah, but the ATX supply doesn't really seem to mind if you hold the button
down for a bit when cycling it on or off (on all the ones I have, you must
hold the button down for a few seconds to turn off, but mostly 'power off'
is under software control, anyway). I expect the OP could use the original
power switch from the AT supply--or the turbo button--as long as he 'cycled'
it instead of simply turning it on or off.
jak
