Capacitor explodes on PSU
Martaine2005
May 12, 2015
5,318
There will be one or possibly two components shorted.
Finding them is usually quite straightforward given the symptoms. Your ability or inability to fault find is important here.
kellys_eye
Jun 25, 2010
6,512
Not sure what your point is, as long as the picture shows what I'm talking about I don't think it matters too much does it.
Pictures of areas of the board YOU think have issues may not show problems elsewhere that you might have missed. Equally, close-ups of individual components don't give the viewer any context to consider what that component may be and how it interacts with parts associated (around) with it.
Pictures that show 'as much as possible' consistent with sufficient resolution for the viewer to pan/zoom around it can often reveal vital information. Otherwise you might end up having to post multiple images in order for the view to 'build a complete picture' of what is going on.
Just my ha'penny.
StanUlam
Mar 1, 2024
3
One thing nobody seems to have mentioned is that the exploding capacitor could have left a trail of metal across a couple of of PCB lands and that is what could be shorting out rather than a component.
Sparkymark
Feb 16, 2024
49
That device is certainly a triac. But what is it controlling?
OK, I have removed the heatsink with the triac and the 2 mosfets on it. I have reinstated the 2 opto's, another mosfet which has just arrived as I broke a leg whilst testing. And I have put a new diode and capacitor on the board. Powered on without the heatsink components and all fine, no explosions.
As for the triac, there is 240v ac going to the small board on pin 1 and the second pin off the board has a trace going to A1 of the triac. A2 of the triac has a trace going back to the centre tap of the 2 main filter caps. Pin 2 and 3 of the board both have the wire that goes to the transformer and the gate of the triac goes to pin 4 of the board. Not sure if any of that will make any sense to you but that's all I see. Thanks
Sparkymark
Feb 16, 2024
49
Just my haha'penny.
Thanks for the input, I'll bear that in mind. Thankyou
kellys_eye
Jun 25, 2010
6,512
Nope, me neither!
This is where another pic with the appropriate annotations on it would make a big difference. I also find it confusing to have to scroll back 'pages' to reference the 'small board' so please try to keep the posts relevant by including the information we need instead of us having to seek it.
Sparkymark
Feb 16, 2024
49
OK, so I replaced the triac. Reinstalled all other components and no bangs or explosions. Happy days. Still no standby and upon further inspection found that chip LD7750RGR PWM controller has an 8 ohm short between pin 2 (comp) and pin 4 (gnd). Am I correct to assume this is not right?
Martaine2005
May 12, 2015
5,318
Not being a @&ck but may be useful to others if you link to it rather than us copy/ pasting or worse, typing.
Difficult to say without the data sheet, 8 Ohms isn’t really a short. It also depends on the circuitry around that chip.
Sparkymark
Feb 16, 2024
49
Sorry don't know what you mean link to it. I removed the chip and tested between the pins. The only other 2 components were pins 3 and 4 of an opto which I removed and tested OK and a ceramic cap which once removed tested OK. I'll attach a pic of the chip. I have a new phone and can't make it screenshot so can't attach pic of datasheet and techy enough to know how to link it. Sorry, I'll try harder in future lol.
Sparkymark
Feb 16, 2024
49
So I've done a diode check between pin2 comp and pin 4 gnd. Getting a reading of 0.016 in both directions. Looking at the block diagram there is 2 diodes and 2 resistors. Can anyone confirm my findings.Datasheet is on previous post
Sparkymark
Feb 16, 2024
49
Well I've ordered some new chips anyway so will compare readings on a new one. Thanks for the help
14,317
Usually you can't measure a complex chip like this with a multimeter.
This chip has ESD input protection on the pins. This protection is usually done by diodes from the pin to Vcc and GND like so (although the datasheet doesn't state this explicitly for this chip). Your measurement may simply show the forward biased pn-junction of the protection diode(s).
Sparkymark
Feb 16, 2024
49
Thank you for the reply, and thanks for the information. Its just that I looked at the block diagram from the datasheet and it shows 2 diodes on pin 2 comp and if I'm getting a diode reading of 0.016 between comp and gnd in both directions, would that be a possible fault.
14,317
Very likely. A diode reads something like 600 - 700 on most multimeters - that's the voltage drop across the pn-junction.
