AT87C5103 ic crack, dsp attack, mcu reverse
Email: [email protected] Skype: techip.mcu.02 Tel: 86-15313166209
The AT8xC5103 contains a standard C51 CPU core with 12 Kbytes ROM/OTP program memory, 256 bytes of internal RAM, 256 bytes of extended internal RAM, a5- sources 4-level interrupt system, two timer/counters and a SPI serial bus controller.
AT87C5103 features:
80C51 Compatible CPU Core High-speed Architecture
X2 Speed Improvement Capability (6 Clocks/Machine Cycle)
16 MHz in Standard or X2 mode
256 Bytes RAM
256 Bytes XRAM
12K Bytes ROM/OTP Program Memory
Two 16-bit Timer/Counters T0, T1
5 Channels Programmable Counter Array with High-speed Output, Compare/Capture,
Pulse Width Modulation and Watchdog Timer Capabilities
SPI Interface (Master and Slave mode)
Interrupt Structure with:
– 6 Interrupt Sources
– 4 Interrupt Priority Levels
Power Supply: 3 - 5.5V
Temperature Range: Industrial (-40oC to 85oC), Automotive (-40oC to 125oC)
Package: SSOP16, SSOP24
If you want to crack the AT87C5103 and other C8051 MCUs, Beijing Sichip( http://www.dspcrack.com ) will be your best choice.
Spehro Pefhany
And now you know how much you should trust a Chinese company with your
intellectual property...
Though there might be exceptions, if you're paying them to defeat the
code protection on a programmed flash MCU, you're quite likely
'trusting' them with someone else's IP.
miso
Outsource to a country that doesn't respect IP, and that is what you get.
