N
N_Cook
- Jan 1, 1970
- 0
Dropped Yamaha XR800F mixer amp, numerous problems mainly around a cracked
board. Crack mechanics dealt with and trace bridges function. But the crack
ended at pin 6 of a 28 pin SRAM Winbond W24257-70LL associated with the
Yamaha YSS234-F digital effects generator. Unless I press the IC case at
pin 6 there is a weird uncontrolled sci-fi echoing howl around efect . Cable
ties thru pcb and around the IC and wooden "folding" wedges to that pin 6
spot have "cured" it. If it does return they will have to switch off the
effects and then a matter of trying to find a replacement W24257 or perhaps
a 62256 would work there. I'm assuming the shock wave propogated up the pin
and disrupted the first bond point inside, is this a common occurance in
such circumstances?
such circumstances?
