Attiny85 vs Pin 1 as an Input
Jouellet
Feb 2, 2015
86
Hey !
working on something that will use an Attiny85.
In a nut shell, I want to detect the presence of something, and via I2C, control 3 LEDs (R,G,B)
So far, I have found most of my information, but still struggling with pin 1.
My planned pin-out is as follow:
1- TCRT5000 sensor
2- Red LED
3- Green LED
4- Gnd
5- SDA for I2C
6- Blue LED
7- SCK for I2C
8- VCC
Now, my problem with pin1, is that it is the reset pin ! Spec sheet mention that it can also be an AnalogIn, which would be suitable for the TCRT5000, but isn't there a chance that I keep resetting the whole thing ?
Can I make sure that it does not happen, other then playing with the fuses, which would require HV to re-program the chip ?
14,317
When configured as input, Pin 1 loses the RESET capability. This should be of no concern once the circuit is operating properly (incl. working firmware).
Be aware, however, that RESET is required for in-circuit programming of an AVR (Attiny). Once pin 1 is programmed as input, you will no longer be able to re-program the chip in-circuit. You will need to resort to what is called HV-programming (HV = high voltage, 12 V) to re-program the chip.
