atx smps help
milan3210
Feb 14, 2012
help i have high output voltage
its showing +5.30vdc instead of +5vdc
+12.30vdc instead of +12vdc
+3.50vdc instead of +3.30vdc
even ps on voltage is +4.90vdc
14,317
Methinks you should reduce the output voltage.
No, seriously: What do you expect us to conclude from that tiny bit of non-information you gave us? Show us your circuit, what are the parameters? Where and how can the voltages be controlled? What are your loads?
Maybe if you bother to look up that information you can answer your question yourself.
Harald
The voltages may be perfectly within spec too.
Rleo6965
Jan 22, 2012
585
Are you using Digital Multitester?
I think this atx power supply was for your PC and your reading those dc voltage on Bios Voltage Monitor. Those were not accurate reading..
milan3210
Feb 14, 2012
smps output
hey olive
this is milan
i m happy to get ur reply on my problem
i found the problem.its the toroidal inductor which makes output voltage high
i changed it and i get perfect voltage
