Audio question- RJ-45 extenders/baluns
Spehro Pefhany
Hi, all:-
What's in these things? A friend is interested in extending some
high end microphone cables (not line level). Does this make any sense?
Some (eg. instasnake) seem to pass phantom power- as well.
Transformers and blocking capacitors per channel?
N
Nico Coesel
Spehro Pefhany said:
Hi, all:-
Not much. The best option is to use shielded twisted pair microphone
cable all the way. I don't see the need for baluns either unless the
cable length is several km/miles.
Spehro Pefhany
What about using CAT5 (4 twisted pairs) to carry 4 microphones?
I've asked what the max length he's interested in. For now, I'd guess
100 feet or more, judging by the 30' tripods he bought.
Best regards,
Spehro Pefhany
N
Nico Coesel
I wouldn't go that route. Microphone signals are very weak. 20dB
amplification is often required to get to line level. A single
shielded cat5 cable for each microphone probably works.
Spehro Pefhany
For length, 50-250 feet, with 100 feet as the nominal is about right.
Do you think they actually have transformers at each end? If so, $300
is reasonable for 8 high quality audio transformers, connectors etc. I
think he'd be p*ssed off if he got them and there was nothing inside.
Best regards,
Spehro Pefhany
Tony
Best regards,
Spehro Pefhany
Microphones are already balanced, and so are mic pre-amps, so baluns are quite
inappropriate..Dynamic mics are 2 wire devices, so connect right onto the Cat5e. Condenser
mics are another thing, and need a return path for the phantom power (perhaps the overall
screen, or dedicate a pair to ground?). I have actually used multiple dynamic mics over a
single Cat5e with no problems of any kind, although I did keep the cable away from nasty
interference sources; I seem to remember that the mic screens were all grounded at the box
at the mic end of the Cat5e. And there might be a case for adding a few small caps across
the receiver end to drain the RF energy from the antennae.
Tony
