Yes, my transmitter's Q3 produces a little heat with a brand new 9V alkaline battery. I can't remember exactly but the supply current was about 55mA so the power from the battery was 495mW. The preamp and oscillator doen't use much supply power so most must be used by Q3, 230mW as heat and 230mW as output I guess. If Q3 is operating in class-C then the output power is more.sssaaa said:hi audioguru
i measure your transmitter .... during transmitting Q3 is producing very littile amount of heat is it right?
A calculation would probably be in error due to unknown stray capacitance. Try 11 or 12 turns on the coils.i want to tune it around 80 MHZ, how many turns of coil do i make?
plz give diagram how to oprate Q3 in class-C.If Q3 is operating in class-C then the output power is more.
My transmitter's mic is sensistive enough to pickup voices in a room where people are about 4m away. Enclosed in an AC jack it might not be sensitive enough.Silicon said:how sensitive is that transmitter for voice?huh? bcoz i need to put it in domestic AC socket(TŪŪ HIDE) and hear whisper in another end of big room.
Hfe (current gain) has nothing to do with a transistor's voltage gain. Since your collector resistor's value is half then the voltage gain is half.if my transistor Hfe is eg. 200 and i'm using eg. 10k collector resistor(for simple voltage amp) when what will be difference if i'll use 400Hfe tran. with 5k collector resistor? i thik voltage gain would be the same
With a collector current of 1mA in a 10k collector resistor, a 20V supply can be used and the collector will swing nearly 20Vp-p. With only 10uA then the collector resistor's value will need to be 10M and its output impedance would be much too high. Base to emitter capacitance would cut high frequencies.if transistor's collector cutoff current is 50nA,when why almost everyone design bias current for 1mA, i think 10uA would be greatly enough.
No. The voltage gain of a darlington transistior is the same as a regular transistor if the collector and emitter resistors are the same. The darlington has a very low input bias current.what do U think about darlington transistor for audio pre amp? i think when transmitter would be superb sensitive. huh?
What are you talking about? A resistor from the transistor's collector to its base makes NEGATIVE FEEDBACK which reduces voltage gain.Silicon said:so Y'ur transmitter voice gain is about 16times,am i right,and i would like to increase it to about ~100times, so i'll need to use base resistor(between base and collector) about 1M,yes?
Hi audioguru
I calculated the frequency of the tank ckt of ur transmitter in which
audioguru I am trying to build ur fm transmitter i have one prob i coudnt find more than one 2N3904 (in my place ) but i Have 3 pices 2N2222 . does it make
I am thinking to change voltage to 6 v camcorder battery (rechargeable) I hope it doesn
