Basic info needed regarding filters (FIR)
I am very new with the subject of Digital logic design and Our teacher
has given us a project of "Implementation of FIR filters" .We have to
use Verilog also.
I just know the clk,reset,set,flip flops designs....
I just want to know what filter is used for and also
Please tell me What do we mean by 4 tap filters.
What does FIR do?
John Larkin
use Verilog also.
What does FIR do?
Google "fir filter."
Quickie starter dose:
A signal, like a sound, can be expressed as a series of samples, each
an n-bit integer. CD music is stored this way.
A filter changes the math. A lowpass filter reduces high frequencies,
cuts the treble. If you have a stream of samples coming in, you can
store the last N of them in a list and process the list to do all
sorts of filtering.
A Finite Impulse Response (FIR) filter takes the list of recent
samples, multiplies each one by some individual factor, and sums them
to make the output.
Filter_output =
(Latest sample * Factor1) +
(1st oldest sample * Factor2) +
(2st oldest sample * Factor3) +
etc, as far as you want to go.
One simple lowpass filter is a boxcar integrator, where all the
factors are 1. The output is just the sum (or average, if you prefer)
of the last N samples.
OK, google+wikipedia will get you the gory details. Good luck.
Coffee's ready.
John
Tim Wescott
sorts of filtering.
to make the output.
"Finite" because if you kick it with an impulse (one lone non-zero
sample in a long string of zero samples) the output only lasts for a
finite period of time.
Contrast this to the Infinite Impulse Response (IIR) filter which has
feedback, and whose response to an impulse is, theoretically at least,
infinitely long.
Filter_output =
Coffee's ready.
John
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Do you need to implement control loops in software?
"Applied Control Theory for Embedded Systems" gives you just what it says.
See details at http://www.wescottdesign.com/actfes/actfes.html
John Larkin
infinitely long.
One of my guys was telling me about the new-new thing, the "wave
digital filter." That's a simulation of a real physical filter, like
an LC or a system of coupled masses, like a Collins mechanical filter
or some such. The key difference here is that every coupling is
bilateral, which gives the filter the quasi-magical sensitivity
benefits that passive LC filters have.
I have for a long time been designing integrator-based "IIR" analog
lowpass filters, state-variable and biquads, and then simulating them
with integer math in a uP, in embedded systems. That's a class of
filters you don't see much in the books, but are efficient
resource-wise and work well, and tend to have reasonable coefficients
that can usually be done with just shifts.
John
Paul Hovnanian P.E.
use Verilog also.
What does FIR do?
There was an article on the basics of FIR filters in a recent* Circuit
Cellar magazine article.
*Within the past couple of months.
V
Vladimir Vassilevsky
It is certainly possible to do digital filters which work like a Spice
simulation of analog filters. It is nothing wrong about this approach
although it is very inefficient and prone to the specific numeric problems.
If the coefficients are done by shifts, most likely it is a dull fulter
with very loose requirements.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
John Larkin
Well, this just works, and seems fairly efficient to me:
.SBTTL . ANALOG LOWPASS FILTERS
; INPUT SAMPLES ARE TAKEN AT THE 139-HZ RATE AND SOFTWARE LOWPASS
; FILTERED. THE FILTER IS A 4-POLE, STATE-VARIABLE (INTEGRATOR-BASED)
; GADGET WITH A 'TRANSITIONAL' (EG, HOMEBREW) TRANSFER FUNCTION.
NODE 1 NODE 2 NODE 3
IN
-->--(+)--[K1:INT]---(+)--[K2:INT]-->--(+)--[K3:INT]---(+)--[K4:INT]-->--OUT
| ^---(-1)--- | | ^---(-1)--- |
'------<----(-1)------------' '-------<------(-1)---------'
; THE FOUR LOWPASS FILTER INTEGRATION COEFFICIENTS ARE ALL EXPRESSED
; AS RIGHT-SHIFT COUNTS, AVOIDING POKEY MULTIPLIES.
; CAUTIONS: EVEN IF ALL INPUTS ARE POSITIVE NUMBERS, OCCASIONAL
; SLIGHTLY-NEGATIVE OUTPUT GLITCHES ARE POSSIBLE.
; BIG SAMPLE-TO-SAMPLE EXCURSIONS CAN CAUSE WILD END-AROUNDS, SO
; IT'S PRUDENT TO KEEP INPUT RANGE BELOW +- 0.25 FRACTIONAL.
; OK, HERE'S THE FILTER. WE USE REGISTERS D0-D6, AND ASSUME
; THAT A0 AIMS INTO A 4-NODE FILTER BLOCK.
; ON ENTRY, D0.L SHOULD HOLD THE FRESH FILTER INPUT.
; FOR SLOW ITEMS, WE USE A FILTER WITH RISETIME OF ABOUT 2 SECONDS,
; CORRESPONDING TO BANDWIDTH OF ABOUT 0.17 HZ. CONSTANTS ARE...
K1 = 7 ; 0.0078125
K2 = 5 ; 0.03125
K3 = 6 ; 0.015625
K4 = 5 ; 0.03125
LOWPAS: MOVEM.L (A0)+, D1 D2 D3 D4 ; SCOOP UP ALL TABLE NODES
; DO THE FIRST 2-POLE LOWPASS...
SUB.L D2, D0 ; MAKE INTEGRATOR K1 INPUT
MOVE.L D1, D6 ; NOW COMPUTE INTEGRATOR K2'S
SUB.L D2, D6 ; INPUT
ASR.L # K1, D0 ; SCALE AND
ADD.L D0, D1 ; INTEGRATE K1
MOVE.L D2, D5 ; SNAP 2ND STAGE INPUT = OUR OUTPUT
ASR.L # K2, D6 ; SCALE AND INTEGRATE
ADD.L D6, D2 ; K2
; NOW DO THE SECOND 2-POLE LOWPASS...
SUB.L D4, D5 ; AND MAKE THE K3 INTEGRATOR INPUT
MOVE.L D3, D6 ; COPY K3 OUTPUT TO MAKE
SUB.L D4, D6 ; K4'S INPUT
ASR.L # K3, D5 ; SCALE AND
ADD.L D5, D3 ; INTEGRATE K3
ASR.L # K4, D6 ; SCALE AND
ADD.L D6, D4 ; INTEGRATE K4
MOVEM.L D4 D3 D2 D1, -(A0) ; REPLACE ALTERED TABLE NODES
RTS
This is fine for lowpass filtering thermocouple data. In situations
where transient response has to be more precise, like high-speed
weighing, some of the shifts can be replaced by fractional multiplies,
which has a minimal penalty on this CPU, a 68332.
John
V
IN
K1 = 7 ; 0.0078125
K2 = 5 ; 0.03125
K3 = 6 ; 0.015625
K4 = 5 ; 0.03125
ADD.L D6, D2 ; K2
RTS
Here is the basic realpole filter which is simpler and appears to have
almost identical response:
const u8 order = 4;
s32 LPF(s32 x)
static s32 z[order];
for(u8 i = 0; i < order; i++) x = z+= (x - z)>>6;
return x;
Making digital filter as the simulation of an analog filter is rarely a
good idea.
use Verilog also.
What does FIR do?
This seems like an odd assignment. Unless this is a class in FIR
filter design, the tap coefficients should be given to you. Seems to
me you will need to know about full adders at a minimum, assuming the
tap coefficients are just a bit or two.
For N wide data and 4 taps, you need 4 N wide D ffs. The data is run
from register to registier like a FIFO. Data is pulled from each
register, multiplied by the tap coefficient, then summed. Unless you
are going to build a stupid amount of logic, the multiplications will
probably have only one or two bits, so the multiplies are really
additions with the data properly shifted. There are overflow issues
to consider.
John Larkin
const u8 order = 4;
s32 LPF(s32 x)
return x;
good idea.
I've sold over 3000 of the temperature controllers that use this
filter. So why is it not a good idea? Why so dogmatic?
More important, my filter has comments and yours doesn't.
John
V
const u8 order = 4;
s32 LPF(s32 x)
return x;
good idea.
filter.
McDonalds serves somewhat 10 billion meals per year. But this fact doesn't
make those meals taste any better or worse :)
I am sorry if you didn't understand 3 lines of trivial C code without
comments. It would be a good idea to do some learning before suggesting the
advanced digital filter topologies...
VLV
John Larkin
const u8 order = 4;
s32 LPF(s32 x)
return x;
good idea.
filter.
Selling things for high prices to high-end customers, in volume, for
years, bug-free, means we're doing exactly what we want to do. Any
other criterion for engineering quality is, literally, academic.
VLV
I've made a solemn vow to never code in C. But comments don't explain
code, comments explain what code is for and what it does. Your filter
is just a heap of code. I have no idea what it's response is like, and
would have to analyze or simulate it to determine that.
So, what is its frequency response?
John
V
John said:
On Fri, 23 Nov 2007 12:43:10 -0600, Vladimir Vassilevsky
const u8 order = 4;
s32 LPF(s32 x)
return x;
good idea.
filter.
Why whining about the Evil Empire of Bill Gates then?
Yes. C++ is lot better.
Here:
1/64
H(Z) = (---------------) ^ 4
63
1 - --- Z^-1
64
John Larkin
Any particular reason?
Mostly because it looks like monkeys with typewriters. And because I
like bare metal programming, where I'm in control of every byte of
data and every byte of code.
I spent a couple of hours yesterday reprogramming the periodic
interrupt structure of an embedded thing I'm working on. Most of the
time was figuring out the ghastly TPU programming, where the vectors
would be, the timing math, led blink patterns, associated user serial
commands, stuff like that. The time to do it wouldn't matter much
whichever language I coded in, and I spent more time typing comments
than typing code.
Uncommented C, or any other uncommented program for that matter, must
be literally decoded, and often simulated, before anyone but the
author can understand what it does or wht it does it. Six months
later, he won't be much better off than a stranger.
I dislike mostly the culture around C. Vlad's example is a good case.
It's as terse as possible, as C was designed to be. Compare that to my
assembly code, which is deliberately opened up for visibility, not to
mention unfolded for speed.
John
John Larkin
const u8 order = 4;
s32 LPF(s32 x)
return x;
good idea.
filter.
Because it's slow, bloated, and bug-ridden, from a company run by
sociopaths who crush competition out of sheer ruthlessness.
Funny! I write apps that run in, typically, 4-6 kilobytes of eprom and
2K of ram, manage a few FPGAs and a VME or serial/ethernet interface,
run thousands of interrupts per second, and have guaranteed response
times in the 100 usec sort of range, 100% of the time. And never
crash.
Here:
1/64
63
1 - --- Z^-1
64
John
John Devereux
than typing code.
I think that is just familiarity. I got the gist of the C code
straight away, without really needing to think about it. I haven't
written CPU32 code for ~15 years. So with assembler you need the
comments just to figure out *what* the code is doing. Whereas with
simple C code, the comments tell you *why*, and what the goal is. They
can be at a higher level.
Jan Panteltje
OK, but to others ASM may look like that.
And I started writing with binary actually.
Pencil and paper, and byte for byte in an EPROM
Was quite good at binary 8080 at one point.
And because I
Sure.
OTOH if you need to write something bigger, like for example
a subtitle editor (that I happened to write) that does audio,
video, text, fonts, animations etc... Cis a better solution
then binary or ASM, also for the fact there are many libraries
one can use.
You give up some control of generated code, but gcc is very reliable.
You can always look at he generated code if needed.
than typing code.
True, when I program PICS for example I do it is ASM, and those things
are often precision things (well in my case, count clockcycles
to ge the timing right etc).
Na, you can write C in a very understandable way, but many do not.
You can make it as cryptic as you want.
Use real variable names that make sense, use spaces, good identination,
add comments, but it is like any language, the more you use it the better you read it.
Greek looks cryptic to me, but not to the Greek.
Portability, especially with Unix, recompile on an other processor: runs.
As available memory increases, each week a new core almost, some
Unix like standard exists, porting or rewriting ANM becomes problematic.
I know, I have written some programs 3 times for 3 differrent processors.
Is tha twhy yo udo not use Linux? It is written 100% in C.
It was very readable to me,
Well, there is math, there is the implementation of math in software, and
in hardware.
I can write a lowpass in Verilog too in one line, would you then draw it
as diagram? I think not.
const u8 order = 4;
s32 LPF(s32 x)
return x;
good idea.
filter.
crash.
1/64
63
1 - --- Z^-1
64
John
I suppose you could use the bilnear transform to map it into the S
domain, then do a spreadsheet to see the response.
Learning basic C isn't that difficult. The object oriented flavor is
another story.
N
Nobody
Comments explain what code is supposed to do. Whether or not it actually
behaves as described is a different matter.
If I don't think that the behaviour of a piece of code is sufficiently
clear, my first response would be to consider re-writing the code rather
than adding comments.
Of course, that's much more feasible in a high-level language than in
assembler.
