Basic LED Info
hi there!
few months back i decided to set up a new line of business and with
research and etc. i decided to enter into energy sector.. more
specifically i decided to jump into solar power. and importing solar-
powered products into my country and market them so as to reduce the
load on electricity..
for start up. i decided to work on solar powered street lights. with
some homework i came to know that LED is the latest thing in light and
its making its way very quickly and replacing the conventional
flourescent, incandescent and sodium bulbs.
however my problem is with the understanding to their power and
wattage and lumens. .i am really confused with all that.. top it all
if i dont understand these all calculations i cannot propose the
required solar panel and battery for any system..
can anyone please help me with this in very very simple language...
i have learned the first formula of (volt * amp = watt)
also i have discovered that there are 5mm and 10mm led pieces that are
commonly used in LED lights. however the availability of 1 watt one
piece, 3 watt one piece and 5 watt one piece LEDs is also
interesting..
also i dont know nothing about the circuits and etc.. have studied
physics in scshool which i hated the most.. but with few bits of
knowledge i have gained now i think it is not that bad.. i must be the
way i was taught.. anyways can anyone help me with that?
according to my research and email with the LED suppliers i have
learnt that 5mm LED produce 2-4 lumens (measuring scale of light) of
light and to produce 1 watt of LED light you will have to put 14
pieces of 5mm LED pieces.. Similarly one watt of LED is equvilent to 4
watt of normal light (the concept of energy savers) i.e. using lesser
energy and producing more light... can anyone validate that?
also with my friend electrician.. i have made some research which
concluded as: 5mm of LED with some power of resistnace consumes
12mAmp. now i want to know that how much amp would it require to lit
up 856 LED in either series or parallel.. i have just used the words
series and paralled.. just know a little bit about them..
similarly how many piece of 10mm LEDs are required to produce one watt
of LED light.. what is their curernt consumption?
what should i understand if one supplier of solar street light quotes
me that the lamp head has a 50 watt LED light.. how much light does
this LED produces when compared to normal light? how can i calculate
the curernt consumption of this light. and also how much power of
battery is required to light up this lamp head for 10 hours..?
my queries may sound silly to most,, but i am a new entrant into this
all..
help will be greatly appreciated?
regards
Allen Bong
hi there!
interesting..
all..
regards
Try this for a start
http://en.wikipedia.org/wiki/LED_lamps
Allen
redbelly
hi there!
interesting..
all..
regards
Your business should hire somebody who is familiar with the
technology.
Mark
Michael Black
haha... how bout get out of the market? Surely you should have some basic
understanding of what you are trying to do before you decide to jump in?
Maybe for the next 6 months learn some basic electronics(these are pretty
basic questions)? That would be the bare minimum.
It probably is a bad career move, but I can't help but think his issue
is not electronic related.
If you're selling lights of some sort, you don't care about what's inside,
you just need the results. And surely there are industry related
magazines, books, or even websites that compare things and define things.
One might also think there are standards in place for things like street
lighting, so one can at least know what the local situation expects. Then
you find a match, or start sampling to find things that match the output
of what's already there. At the very least, such things are defined in
some municipalities, so one could dig some sample information up if
the local municipalities don't have such information.
I would also think street lighting isn't something a municipality walks
in off the street to buy, they issue tenders and companies bid. The
tenders should provide information on what's needed. The winning
bidder has to provide not just what is wanted, but at a better price
than the other bidders. And if one wants to sell a product that is new to
a field, one may have to do some initial work, doing research on what's
new and available and presenting a case for changeover to such a system
(remembering that the issue isn't just about what gets saved with the more
efficient lighting, but one actually has to pay for the switchover which
may be more of a burden than the current spending for the power to
inefficient lighting.
One may have to spend money, setting up samples, to showcase the new
thing. Indeed, a municipality may be more willing to try something
new in a new area than to start with replacing existing lighting.
For many people, lighting is either too little or too much. They don't
have a proper feedback system for specs, even if the specs are given. Look
at all the LED flashlights now on the market, there is no way to compare
then in the package, they either don't say anything about output, or they
give nebulous things like "1W". And they aren't generally arranged so
you can try them in the store. But buy them, bring them home, and try
them, and instantly you know that one is better than that one, because
you see the results. If they all had specs, the specs still likely
wouldn't mean much until you actuall went through a few of the real
flashlights, to conenct the specs with a real world example.
Michael
Jon Slaughter
hi there!
interesting..
all..
