Beginner circuit help.
Dan Schuman
I'm working on a circuit to help learn all this jazz, and wonder how
this could be accomplished:
Two devices to be used on the circuit are a speaker and an LED.
Source: 12V battery (Two 1.5V + 9V batteries)
LED: 3V / 20mA
Speaker: 12V / 15mA
(I am aware these devices operate at varied amperes and such, but I
would ideally like these to work at these specific values for
educational
purposes.)
How could I design a circuit that houses both these devices at their
rated amps? Right now I'm putting a parallel circuit near the
beginning to cut up the amperes, but then I seem to get stuck when
trying to use the lower voltage device at 20mA.
Any help?
Randy Day
[snip]
Assuming you mean to use the LED across the 12v
supply, you use Ohm's Law like this:
Supply voltage - Led voltage 12 - 3
R = ---------------------------- = ------ = 450
LED current .02
Then use a 470 ohm standard value resistor in
series with the LED, like so:
+12v -----[R]----|>|---- Gnd
| LED
Spkr
Gnd
HTH
Eeyore
LED: 3V / 20mA
Speaker: 12V / 15mA
educational
purposes.)
You haven't even said what you want to do with the speaker and led !
Graham
Eeyore
| LED
Spkr
Gnd
And putting DC through the speaker will achieve what exactly ? Other than
heating the voice coil and draining the battery.
Graham
Randy Day
| LED
Spkr
Gnd
He referred to a '12v' speaker; I'm guessing he
means a powered speaker/amplifier. If I'm wrong,
it's still a learning experience.
neon
Oct 21, 2006
1,325
lame idea a speaker is an ac device works fine with ac put your 9v battery and poof no speaker. the LED is a dc device even though it can be modulated you /I can see it for the same reason I CANNOT SEE 6O HZ LAMPS FLASHING. VERY DENSE.
