Bench power supply to PCB connector
djay
Mar 4, 2022
I have a bench power supply and I was wondering how I can connect it to a PCB board with a right angle male 4-pin connector?
AnalogKid
Jun 10, 2015
3,056
Your question is missing so much information that it is difficult to know where to begin. The answer you deserve is : Simple; use wires.
Beyond that, let's start with the basics:
What power supply?
What pc board?
What voltage?
What current?
Physical limitations - height, depth, cost, shielding, mechanical stress, etc?
ak
djay
Mar 4, 2022
My bad about that, the power supply in question can provide 30VDC of voltage and up to 3A of DC current, and I don't have details for the pcb since its a theoretical question and we assume there aren't any physical limitations
AnalogKid
Jun 10, 2015
3,056
OK, that limits your choices to only 0.314 jillion options. What cable technologies do you have? Crimp pins pushed into a body? Insulation displacement? Solder cup?
Also, some very common connectors have a surprisingly short lifetime in terms of insertion/extraction cycles. What kind of workout will the connections experience?
To start, look into TE (Tyco, AMP, whatever) MTA and MTE series (0.156" spacing), and the Molex Mini-Fit series.
ak
Martaine2005
May 12, 2015
5,317
What are the 4 wires?
If there are no limitations or restrictions, how would you like to connect them?
How do you envisage the finished product?
Will it be easy to connect and disconnect?
Martin
