Bluetooth modules
Spehro Pefhany
Have a LOW-volume mobile data acquisition application that requires
Bluetooth. Not sure yet whether it will be Class I or II. Any
suggestions as to good, reliable OEM modules? Unit cost is not a big
factor. What's the situation with FCC/Industry Canada? I presume that
type approval is required?
Best regards,
Spehro Pefhany
Meindert Sprang
Hi Spehro,
Take a look at these: http://www.blu2i.com , especially the bare module.
You can download datasheets from their ftp site:
ftp://tdkuser:[email protected]/
The modules are certified as an end product and therefore do not need any
extra approvals. Just plug them into your application and you're ready. The
modules can be programmed by modem style AT commands and can be setup as a
'serial-wire' replacement. You make the right settings with a few AT
commands and then two paired modules operate autonomously as a fully
transparent serial channel. In Europe, they sell for about 85 euro/unit,
which compares to appr. $100.
I have used them to put BT functionality into a data multiplexer, so any
Bluetooth device (PDA, PC or what have you) using the serial profile could
talk to the multiplexer.
Meindert
Spehro Pefhany
Hi Spehro,
Yes, that's just the sort of thing I'm looking for. Thanks for the
suggestion, Meindert. They are made by TDK, I presume.
Best regards,
Spehro Pefhany
Ben Jackson
You can get SDIO cards that do bluetooth. That's a device in the
SD/MMC form factor. I'm not sure what's involved in driving one.
Meindert Sprang
Yes. And they contain (as many others) a radio chipset from Cambridge
Silicon Radio.
Also the support for these modules is very good. You can mail directly with
one of the software developers of the module and he is very responsive. But
he is in the UK so mind the time difference.
Meindert
Bradley
You may also want to check out Wilcoxon Research (www.wilcoxon.com).
They have an industrial Bluetooth module with a 100m range. I have a
couple sitting on my desk, but have not had the time to test them,
yet. Their engineers were very helpful as well.
Bradley
Michael Anton
Since nobody else has pointed this out, I will. RF does not go through
aluminum, so you will need to have an external antenna, or have sufficiently
large enough cutouts in the box that the RF will "leak" out.
Mike Anton
Best regards,
Spehro Pefhany
http://www.speff.com
Spehro Pefhany
Mike Anton
Thanks. ;-) It's a plastic (polycarbonate) enclosure, but I could
imagine someone making that mistake. Once.
Best regards,
Spehro Pefhany
Ethan
Some plastics will absorb RF energy and will seriously attenuate your
signal, so you still want to be carefull of what type of material you
use for your box. I don't know about polycarbonate. I have heard the
way to find out if a plastic will work well is to put it in a
microwave oven with a glass of water, and see if the plastic gets hot.
Both microwave ovens and Bluetooth are at 2.4GHz so the plastic will
absorb energy from both in the same way.
Ethan
