BMP085 - ADC converter type ?
syncout
Nov 27, 2017
4
I have read BMP085's datasheet and it says BMP085 has a 16-bit adc converter, and it takes 8MSB and convert it, and then it takes 8LSB and convert it too. I'm not 100% sure if it is correct, but if I am wrong, so is it a SAR adc? Because I don't know another adc that uses MSB and LSB to covert signals.
And, if it is as I said, why does it take first 8MSB and then 8LSB?
Thanks!
datasheet: https://www.sparkfun.com/datasheets/Components/General/BST-BMP085-DS000-05.pdf
14,306
Where did you read this? I can not find any reference to this in the datasheet.
syncout
Nov 27, 2017
4
Thanks for you quickly reply!
Well, I am not pretty sure about what I'm talking, but I found "this information"(probably wrong) on page 18.
14,306
What's stated there is that you read the 16 bit A/D conversion value by reading 2*8 bits.
This is no reference to the actual mode of conversion.
syncout
Nov 27, 2017
4
Do you guess why does it happen? If it is a 16-bit A/D converter, why does it takes 2*8bits? It is confusing to me.
Thanks for your reply!!
And because they would need 8 more pins to output all 16 bits at once.
Duh, I shouldn’t have posted without looking at the datasheet. :oops:
