Board Design Programs?
crazy_azz_mat
Apr 24, 2005
3
I am looking for some pcb designing programs. Something simple to use and relatively cheap maybe even free  ;) Ive tried UltiBoard from electronics workbence but thats too complicated. I just want to design single layer boards. Any help?
Thomas1
Feb 20, 2005
29
I use Target 3001. You can get a free demo at http://ibfriedrich.de.
The demo can handle up to 100 pins (enough for small projects). A 50€ Version gives you 400 pins.
EdwardM
Apr 12, 2005
246
Hi crazy_azz_mat
I've used Target 3001 and it's very good and has lots of support.
The one I currently use is Eagle as I find it slightly more intuitive to work with, it too has lots of support on the web in the form of tutorials, FAQ's and libraries.  The free version has a size limit of, I think, about 10x8 cm, which is more than big enough for general projects.
Whichever program you end up with, you'll find you need a lot of practice to become proficient and I've yet to find one which is easy to use in making new IC's/packages - it can be done but I don't find it simple.  ???
Best of Luck
Ed
prateeksikka
Jun 19, 2004
736
hi there!
ORCAD CAPTURE WITH LAYOUT EDITION AND PROTEL ARE VERY HANDY WITH PCB DESIGN AS THEY HAVE AN OPTION OF AUTOROTING THE BOARD. ;D
PRATEEK
Platonas
Mar 29, 2005
15
I will sugest 3 different products that look good and are cheap.
1. Proteus (w*w.labcentre.co.uk)
2. CircuitMaker (w*w.circuitmaker.com) and
3. Eagle (w*w.cadsoft.de)
Proteus is supposed to be more inclusive since it has a simulation ability.
Circuit maker has also simulation abilities but not for microcontrollers as Proteus has.
Eagle on the other hand is (my opinion) better that the other 2 as far as schematic/PCB abilities are conserned.  Its libraries are very good, has good support and it is the cheaper.
The easyer to use is Circuitmaker then Eagle and then ....
All of the above have schematic editor, pcb and autorouter.
