Breadboarding
Eeyore
Now, only a little while back I said I never breadboard, I go straight
to pcb.
This one's different though. The client wants to do the layout as part
of a larger scheme and I want to be double sure of stability in practice
as opposed to simulation because if he messes up, I can show mine
working fine.
As I'll be using a 65MHz ? op-amp I don't trust perfboard / Veroboard
for this.
I recall some self adhesive 'pre-etched shapes' that you could stick on
a ground plane. The name Wainwright comes to mind but google isn't
helping much.
Any suggestions ?
Graham
to pcb.
working fine.
for this.
helping much.
Any suggestions ?
Graham
surfboards?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=9161CA-ND
N
Nico Coesel
to pcb.
working fine.
for this.
helping much.
Any suggestions ?
In these kind of situations I create a small PCB to test the circuit.
neon
Oct 21, 2006
1,325
For 65mhz any breadwork or PCB will be fine but the acid test is the final inplementation. Will it work as desired?
Eeyore
to pcb.
working fine.
for this.
helping much.
I was right about wainwright but was getting too many hits to filter. Then I
recalled (from 28 years ago !) that the product was called "mini mounts" and
google this time got it.
http://www.google.com/search?hl=ena&rls=en&hs=C5r&q="mini-mount"+wainwright&btnG=Search
I don't recall it being German and I can't find a site selling any. I'm sure
there was a company in Bristol UK that sold them but maybe they've fallen
out of favour ? They were very popular for RF work in particular.
Graham
Eeyore
John said:
If you're in a hurry, build it live-bug on a piece of copperclad.
Things like this can help:
http://www.beldynsys.com/singledual.htm
But it's usually easier to do a quick-turn PCB.
Can't disagree there but this is so few components !
If the timescale allows, we might be able to tack it on to another couple of
boards we'll be doing.
I did recall the product name in the end and google found it. Interesting but
brief comments from Bob Pease at the bottom of this link from there.
http://electronicdesign.com/Articles/Index.cfm?AD=1&ArticleID=6105
Graham
DJ Delorie
Eeyore said:
Similar kind of thing. Except I only need a handful !
Next time someone tells me I'm wasting my time making my own boards,
I'm going to point them at this thread :)
Last time this came up, it got me thinking. I can etch on 8 mil FR4,
and double-stick tape that to an unetched copper clad board, to get
what I think you're asking for. But, not being an RF expert, I have
no idea how well it would "work". I think it would be worth the
effort to find out if this is a viable RF prototyping platform, just
to satisfy my curiosity, if you can send me a PDF of a SS layout (no
vias ;). Contact me off-list if you're interested.
DJ
Rich Grise
Not terribly convenient for the UK sadly. That's the sort of thing but you
could get individual IC package 'stick ons' and strips for
interconnections etc.
How about pad-per-hole perfboard (preferably with ground plane on the
other side) and either fine wire or copper tape?
Have Fun!
Rich
Eeyore
I only wish I could send you a Wainwright 'Mini-Mount' catalogue. I bet I
have one somewhere here in the archive.
It's just such a breeze to use. It could be a useful side income for
anyone.
Graham
Eeyore
Never seen one with ground plane on one side.
Graham
Rich Webb
Also look at http://www.schmartboard.com/. Reasonable prices and their
newer boards use what they call "EZ technology" -- basically the
solder pads are recessed below the board surface. Carried by some
distributers over on this side of the pond; not sure about y'all tho.
Farnell used to stock a prototyping board with a "collander ground
plane" on one side.
C.I.F. stills seems to make something like this
http://www.cif.fr/new/produits_aff.php3?cat=1&scat=1&sscat=3&p=169
as the AL 201 at the bottom of the list.
Farenell stocks it under order code 1201481. I'm fairly sure that this
isn't the part I used but it does seem to be the same kind of
prototyping board.
Eeyore
Tim said:
Make a layout on Eagle or your fav' tool, and get it fabricated at a
fast-turn PCB house. If you're charging a reasonable rate you'll spend
less than two hours (and probably one) for a small hand full of 2-sided
boards, and you'll save more time than that by not having to fiddle with
a new technology or agonize over whether those stick down strips (or
whatever) are really doing their job.
And you'll have a much closer model to the real thing.
If you were in the US I'd send you to PCB Express
(http://www.pcbexpress.com/).
How do they compare to expresspcb, whom I have used ?
Graham
anyone.
Graham
" I only wish I could send you a Wainwright 'Mini-Mount' catalogue. I
bet I
have one somewhere here in the archive."
Do these things still exist? I've heard about them from several
different souces now,
You can get double sided pcb's cheap, and I've always wanted surface
mount "jumpers" for prototyping.
George
Eeyore
Paul Hovnanian P.E. said:
So, who is responsible for seing to it that the production version of
this gizmo will actually work?
The ultimate client. They just want a circuit.
Graham
DJ Delorie
Perhaps you could just buy thin copper tape and cut out the shapes you
need?
DJ Delorie
John Larkin said:
You can get down to about 100 ps, 3 GHz or so, with Xacto knives and
copperclad. Kapton tape can be really helpful... stick down a small
square, notch out some ground windows, and solder the parts on top.
I think I've seen that before. Still curious how well thin FR4 over a
solid plane works, though. Plus, I like etching more than xacto-ing.
And etching is easier for really small details, too.
Eeyore
plane" on one side.
prototyping board.
So near but so far !
If only I could get my hands on those Mini-Mounts.
Graham
