F
Fred Kruger
- Jan 1, 1970
- 0
Dimbulb had one of those, but it was always run down.
More likely, the spring broke from over-winding after all that up and down
wrist action.
Jeroen said:I think the real question is: Why do we need myriad formats when we
have tar? It probably predates them all. All those young whipper-
snappers keep re-inventing the wheel. Oh well.
Jeroen Belleman
(Now let's have some archive format history...)
Phil said:Tar is not a compressed format--zip dates from the days of 360k
floppies, remember!
John said:I'm offering free data and advice, and you're whining about the price.
And it's not a web page, it's an FTP site.
And my camera makes jpeg's, not gif's.
Did I leave anything out?
John
Jeroen Belleman said:The whole philosophy of UNIX-like
systems used to be to have programs that did one thing well, and
that you could pipe together in various ways. This is amazingly
powerful, once you get the hang of it.
This is totally lost on today's developers, who all seem to make
programs that do-it-all-and-then-some. That leads to many different
implementations of the same sort of functionality, all incompatible
to some extent and all with different idiosyncratic bugs.
Fred said:More likely, the spring broke from over-winding after all that up and down
wrist action.
JosephKK said:It has been called creeping featuritis. Its roots began in the early
1960's with FORTRAN II and PL1.
I'm sure Terry Given or anyone else in the business could tell stories
about induction heaters and rings, or something like that. ;-)
JosephKK said:Not entirely true. There has been many implementations of GUI over
CLI implantations that were very effective and provided piping
capabilities.
James Arthur said:Hi-Q resonators?
But make sure you know what's in that ceramic material ...
III. LOW RISK OF HARM FROM EXPOSURE
8) As stated already, only 1-10% of the population is susceptible, so
multiply any above risk by that factor.
That depends on where you bought your ring now, doesn't it?![]()
The Eclips ecl gates (the MC10EL and EP parts) swing almost 0.9 volts
in about 220 ps, which is perfect for slamming the gates of modern
phemts. Analog Devices makes some comparators that are a lot faster,
ballpark 40 ps with ecl swings. I'll have to try driving a phemt from
one of them, just to see.
Some of the lvds line receivers will swing 3.3 or 5 volts in roughly
600 ps.
John,
Have you ever experimented with CML logic gates instead of ECL? I
mean something like the NBSG16M. The swing is somewhat reduced (about
400mV) but they seem pretty fast (at least from the datasheet).
http://www.onsemi.com/PowerSolutions/product.do?id=NBSG16MMNG
Allan
.... said:We use an NBSG16VS as a variable-swing pulse generator. It gens a
fast, programmable-level pulse that we feed into a couple of Hittite
distributed amps, to finally get a 0-6 volt pulse that drives an
optical modulator. It all works nicely, very clean and fast. All three
chips are power-pad mounted with heatsinks on the back side of the
board. The NBSG costs $32, and the Hittites are about $200 each.
PCB:
ftp://66.117.156.8/AmpTop.jpg
and output into 50 ohms, 1 volt/cm:
ftp://66.117.156.8/NewSq2.jpg
The NBSG would be a nice TDR step generator.
John
Superb waveform! Are the hittite amps DC coupled or do you clamp the
output somehow?
Today I have been playing with a 74LVC00A which was available in some
drawer to generate "narrow" pulses from a square signal in the quick and
dirty way:
| |NAND---NOT--
|-NOT-| /
In -------- -------
_ _
Out------| |------------| |----
Output pulse width is rougly 2.5ns with a leading edge rise time of 1ns.
It fills the spectrum quite nicely up to 1 GHz. (Currently targeting the
0-1GHz part of UWB spectrum -impulsive flavour).
The NBSG16VS would probably allow to take this some steps further. Have
also looked at the MC10EP05. However, from the ON-Semi datasheets I
can't figure out how fast the input edges should be. Is there some
schmitt-trigger built into the inputs? How fast will the output edges be
for say 2ns input edges? Do I only have to care on the time it takes
through the V_IL-V_IH zone?
JosephKK said:I can't name any off the top of my head, but perhaps xemacs qualifies.
