breaking the speed of light article on howstuffworks.com
John Woodgate
I read in sci.electronics.design that ~~SciGirl~~ <[email protected]>
wrote (in <[email protected]>) about
'breaking the speed of light article on howstuffworks.com', on Sat, 5
Feb 2005:
Traveling has one L, not 2. That I'm pretty sure of.
One of the several differences between the spelling of US English and
British English. These terms are not a joke; they are taken very
seriously by professional translators, who have to translate, say,
Russian into whichever sort of English the client wants.
A few days ago, someone here asked what a 'chook' was. It's Australian
English for 'chicken'. There are a lot of special words like that in
Australian English.
John Woodgate
I read in sci.electronics.design that John Larkin <jjSNIPlarkin@highTHIS
landPLEASEtechnology.XXX> wrote (in <bgha01ho2mnfl94qbvb9uhc3o8hs3l5klg@
4ax.com>) about 'breaking the speed of light article on
howstuffworks.com', on Sat, 5 Feb 2005:
What sort of voltage does it take to get electrons to relativistic
speeds? I used to know that. Maybe the voltage that, ignoring
relativity, would boost an electron to C. Something roughly 100 KV, I
recall.
For early colour tubes, the geometry of the deflection region was so
critical that electron speeds around 10% of C required relativistic
effects to be taken into account. IIRC, the EHT was around 25 kV.
Robert Baer
keith said:
<shrug> Now measure the falling delay.
<snipped irrelevant stuff>.
Circuitry and instrumentation do not care if an edge goes positive or
negative, or which edge is making the change, or how much of a change.
Robert Baer
Ken said:
I actually got a spec from some fairly smart people that said that one
pulse had to be produced before the other. The later pulse was called the
"trigger" and was supposed to be the external input to the circuit.
What they really wanted was a circuit that made two pulses that partly
overlapped. They didn't really want to have to provide the "trigger"
input.
Reminds me of the HP212 pulse generator (if i remembered the number
correctly).
One thyratron turned on, making the output go positive by discharging
a cable into the load.
A second thyratron would be triggered at a varied time afterwards
(contolled by the pulse width control on the front panel).
That thyratron (if i remember correctly) discharged a second cable,
creating an opposite polarity pulse. An alternate possibility was the
second thyratron was used to short out the ouput.
In any event, one could have a unit where the second thyratron would
trigger before the first.
I presume some idiot would then say that the resulting output pulse
would have a negative length?
What one saw on the scope at low amplitudes, was the triggering pulses
to the thyratrons.
Robert Baer
Mark said:
It is compelling to believe that there could be some way to exceed C. On one
hand, it's great to be "pushing the envelope" by researching such things, but on
the other hand, don't let simple lust blind you into believing something is real
when it is not. Any theories are just heresay until proven otherwise. This
reminds me of a post I saw here recently which went something like this... (use
a monospaced font like Courier):
Scientists Discover New Waveform:
| _______) \______ |
| Time--> |
The Sharktooth
Here's my two cents. Einstein's Time/Frame notion - and the notion that light
can travel faster than C with respect to other light - seems to be consistent
with observations made scientifically. i.e., measure the speed of light on two
opposing edges of an expanding universe from the center, and they have an
escaping velocity *delta* faster than C. But no light actually travels faster
than C in it's frame.
The other idea is that if string theory is correct, what if "FTL" is simply the
12th dimension? (I can't stand that vagueness about string theory - "if
something doesn't work right, just add another dimension...")
That said, also interesting the the propagation speed of EM radiation with
respect to C in various mediums. Research for instance, the speed of "c" in an
iron powder medium; the answer might surprise you.
-- "I think the state of the universe at the moment of conceptulization
determines part of how an entity further interacts with the rest of its reality,
and hence our experience with it." MCJ 200311
As i remember it, the characteristics of a tahcyon (FTL photon) or
other FTL item was: The more the friction it encountered, the faster it
would go, and its limiting velocity was on the low end, or C.
Had to put more energy into the tachyon to slow it down closer to the
speed of light.
That is to say, no matter which "side" of C one was talking about,
more energy had to be used to get the object to travel closer to C.
Symmetrical equation.
Robert Baer
~~SciGirl~~ said:
"I think John Larkin said it best: "If there's something going faster
than c, it's not a photon." And, according to the definition of
"photon", that's absolutely true."
All right, so I'll rephrase that. No PHOTONS were going faster than c,
but we haven't proven that tracheyons aren't (I've seen that spelled so
many different ways, so I don't know if I'm spelling it right.) Is that
basically saying that, if a photon was to move >c, it would have to be
called a tracheyon?
Yup!
Robert Baer
~~SciGirl~~ said:
"14 = 9th grade? Algebra, sounds about right. You're doing well. Keep
up
the interest."
Actually, 8th grade, but in 9th grade math. Still in 8th grade science,
but will be working on a research project a couple days a week instead
of class because class got too easy for me and I was bored to death.
They're doing convection, conduction, and radiation. It's like sitting
in a chair for an hour listening to a repetitive explanation of why one
plus one equals two.
Do not get too bored..electronics gets involved in measuring a lot of
things, from controlling the temperature of something (room, veggies,
drugs) to detecting gluons, pions; navigation, communications
satellites, und so weider.
And guess what? The third law of thermodynamics guarantees that all
electronics will get warmer.
Maybe even hot.
Where and how can that heat be transported elsewhere?
Heat pipes are rather efficient: why? How do they work?
Convection and conduction are also useful mechanisms; how do you
design a home for energy efficiency, but allow air exchange so the poor
tenants do not get sick?
How does one get rid of that heat in a satellite; how does one get the
heat from various electronic packages inside that satellite to the
surface?
Yes, the basic concept of heat flow is boring, but...the techniques
involved can get a little esoteric - and the calculations rather
involved and even into major useage of 3D calculus.
Robert Baer
~~SciGirl~~ said:
Just for the record... I intend to be a meteorologist when I grow up,
not a physicist.
Computer modeling in that field is still in its infancy.
Someone with the right background and training could *visualize*
scenarios, and make mental changes to "home in" to predictions of (say)
tornadoes, rain, etc a lot faster and more accurately than any computer
modeling that will be available even in 10 years.
Example:
Nicola Tesla had a full electromechanical laboratory in his head; he
would design a motor or a generator with certain materials and
specifications, then put it into use and thereby see what speeds would
destroy it (and why). Then change the design based on that experience
and try again.
The results of these visualizations mimicked exactly what would happen
if the motor or generator had been actually built.
Robert Baer
~~SciGirl~~ said:
If there was some way to achieve a negative volume (it seems SO
impossible but who knows?) what would happen to the matter? Say we had
a piece of metal, and accelerated it past C. From another frame of
reference, you'd see it getting shorter as it approached C. If it went
faster than C, would it eventually become something with mass but no
volume, and then start regaining its volume in the opposite direction?
(ugh I don't think I'm explaining myself very well, I need a picture of
some sort.) It's kind of this idea, and absolute value comes in
somewhere, but I can't really express it well. Say speed was a number
line, and C was zero. We so far can only move on one side of C. What
would be on the other side, if it exists? Which side are we on? Or is
this way of thinking about it totally one hundred percent impossible
and wrong?
Start simple; push a bullet, a rocket, a photon.
*Special* theory of relativity predicts that one must use more end
more energy to make that move faster, as it approaches the speed of
light.
*DISCONNECT*
Be G*D and know of two galaxies on "opposite" sides of the expanding
universe.
Us dirtbags (err..Earthlings) have learned that galaxies move faster
the further away they are (from us and presumably from the center of the
universe AKA "big bang").
So, those two chosen galaxies could easily be moving away from each
other at (say) 10*C.
The how of that did not violate *special* theory at any time during
their life, and certainly can never do so.
*GENERAL* theory comes into play, and basically states that there can
be absolutely *NO* communication between them.
So a dirtbag on one would (and could) never know that the other galaxy
existed, or where (unless G*D gave that information to her/him).
Robert Baer
Feb 2005:
I've just asked you roughly the same question in a previous e-mail! It's
because of paradoxes such as you describe that we take Special
Relativity to mean that FTL for objects made of matter isn't possible.
Regards, John Woodgate, OOO - Own Opinions Only.
The good news is that nothing is compulsory.
The bad news is that everything is prohibited.
http://www.jmwa.demon.co.uk Also see http://www.isce.org.uk
And rightly so!
One simply cannot find enough energy to accelerate any particle to
0.99999*C!
Robert Baer
~~SciGirl~~ said:
This is a question I have had since reading about Maxwell's
equations... in each one of them, there is this upside-down triangle
symbol that looks just like the delta triangle flipped over. What is
this symbol and what does it mean???
I took a quantum physics test on allthetests.com (to find it just type
"quantum" in the search box, there is only one) and I scored 8 out of
12.
If i remember correctly, the term is "del" and i never learned those
operators.
I am guessing they are 3D vector operators used in a form of calculus
(could be very wrong).
There are other "nasty" mathematical things: dirac function,
theoretical derivation of shear and torque come to mind.
Robert Baer
Feb 2005:
It's called 'del' or 'nabla', and it's a symbol in calculus. You said
'no calculus', so it's a bit difficult to help you any more. The first
paragraph at the URL:
http://www.hypercomplex.com/education/intro_tutorial/nabla.html
gives you the history, but then it goes deeply into vector calculus in
three dimensions.
Thanks for the ref! Seems my wild guess was not too far off..
Robert Baer
~~SciGirl~~ said:
It all drives me mentally crazy, it's really abstract. I try not to be
bothered by it, because someday it might be figured out. Some things
maybe should be left unknown for a time. I believe there is a form of
energy we haven't discovered yet that will explain such things, and
that there is some property of it - and I'm not quite sure what, just a
vague idea - that can somehow be flipped or inversed or something like
that. It's hard to explain because it is really just a vague idea in my
own mind.
I'm not going to just rule out the possibility of exceeding C, though,
because the equations say it's not possible. Maybe we need to further
revise our perceptions of space and time, not the equations, or
something like that.
The amount man knows in comparison to the amount there is out there to
know is ridiculously tiny, so we really cannot rely on the equations.
Every fundamental quality of the universe we describe might be
incorrect.
Sorry to repeat; the difference is in what the *special* theory of
relativity correctly predicts, and what the *general* therory states
concerning !different! frames of reference.
John Woodgate
I read in sci.electronics.design that Robert Baer
about 'breaking the speed of light article on howstuffworks.com', on
Sun, 6 Feb 2005:
universe.
There is no 'center': the expansion is not from a point but from every
point.
We don't know, and may never know, whether expansion at superluminal
speeds is possible, because there is an event horizon where the
expansion speed is C. We can get no information, as far as we know at
present, from beyond that horizon, which is formally called 'the
boundary of the observable universe'.
Yes, it does, because it presumes matter moving at superluminal speed.
GR isn't required for that. See above about the event horizon.
The conclusion is true.
Y
YD
No, that's sarcasm.
When are you going to either get a real ISP with a real news server, or
learn to quote stuff on the google chat room page?
Sign up at http://news.individual.net for a free account.
Xnews, Xananews, Free Agent, Microplanet Gravity for free readers.
Grab the lot from http://www.nonags.com/nonags/newsr.html and give
each a try. Keep the one that suits you. SLRN if you're on Linux/*BSD.
So lunch may not be free but there's sure a lot of software out there
- YD.
Jim Thompson
Try stopping 10, 41 year olds on a street corner and see if they do. I
doubt more than half do.
IMNSHO, I would expect _maybe_ ONE to _understand_ Calculus, most of
the others _may_ have _heard_ of Calculus.
...Jim Thompson
K
keith
Ah, so I should have only specified one edge delay and let everyone guess
the other?
IOW, *nonsense*!
K
keith
PAN for Linux is quite Gravity-like. There are tons of others (I've tried
KNode too, but didn't like it's "online" reading)
Yep, and as you pointed out, free servers. ...and at least one *good* one.
K
keith
On Sat, 05 Feb 2005 12:21:20 -0800, John Larkin
[snip]
Brings back the horrors of Field Theory class. We had a Japanese
instructor who was as brilliant as he was unintelligible. Luckily for
us, he was junior in seniority so also had to babysit us in the
afternoon EE labs. So we came to an understanding: he'd give us really
easy Fields tests and everybody would slip out of afternoon labs
early. We just faked the lab results, which made much prettier graphs
than we could get using the ancient equipment in the lab.
I developed a certain sloppy slide rule technique that produced
excellent data point scatter.
John
At MIT we called it "dry lab" ;-)
So, as we see, Mr. Thompson and his ilk learned the techniques of
self-deception quite early on in the indoctrination process.
s/self-deception/survival/
