breaking the speed of light article on howstuffworks.com
richard mullens
~~SciGirl~~ said:
"I think you're really 41"
If I was 41, I'd understand calculus, wouldn't I?
Calculus is easy. But first, you should measure the slope at various points on the curve Y = X squared or cubed.
Once you have done this several times (and it is laborious) you will be able to appreciate the value of being able to calculate
slopes (gradients) instead of measuring them. That is the Differential Calculus.
After that comes the Integral Calculus. That too is a doddle, it is about calculating the areas under curves by summing very
small slivers. But as I said, to really appreciate its utility and beauty it helps to have done these things the hard way first.
I posted this before. You should watch the physics lectures - they are very good indeed - here's what I said:-
At the risk of swamping their website, for those who want to brush up their Electromagnetism, I think that the Video lectures at
http://ocw.mit.edu/OcwWeb/Physics/8-02Electricity-and-MagnetismSpring2002/VideoLectures/index.htm are pretty damn good.
Aside from these videoed lectures, I found just 3 others:-
From the same professor:-
http://aka-ocw.mit.edu/OcwWeb/Physics/8-01Physics-IFall1999/VideoLectures/index.htm
and two mathematics lectures (Linear Algebra):-
http://aka-ocw.mit.edu/OcwWeb/Mathematics/18-06Linear-AlgebraFall2002/VideoLectures/index.htm and
http://aka-ocw.mit.edu/OcwWeb/Mathe...r-Engineers-IFall2002/VideoLectures/index.htm
Most of this is 1'st year university stuff.
You'll need RealPlayer to watch the lectures
Of course there is lots of other stuff - maybe something of interest in Aeronautics & Astronautics and some stuff in mpeg format.
~~SciGirl~~
lol, I have looked at the slope on y = x^2 when we were using the
graphing calculators in math and I finished my worksheet. I had nothing
to do, so I decided to graph random things on the calculator. I haven't
tried x^3. I don't understand trig yet, and I don't know what sine,
cosine, and tangents are, but I do know what the graphs of the look
like. (once again, from experimenting with a graphing calculator)
ok, so I've picked up that calculus is change in variables or something
like that...
~~SciGirl~~
I have real player, but the lectures aren't working. Maybe it's because
I'm on the windows 98. I'll try again later on the better computer.
~~SciGirl~~
there are some really interesting articles on antimatter on nasa.gov
K
keith
Also, what exactly would be the point in saying I'm 14 if I was 41?
That wouldn't benefit me in any way.
You tell us. Who was saying otherwise?
Hint: dump google groups
K
keith
Army core of engineers? :)
They do a fine job literally leveling mountaintops when they build earthen
dams, moving the Earth seems like it might still be within their charter...
Requisition: FBL, one each. (F'n big lever)
richard mullens
like that...
Here is my best advice:-
Throw away your calculator.
Maybe it's a bit extreme - but unless you understand how the underlying mathematics works it won't help you to succeed - except
in finishing worksheets.
Once you know what a Sine is, you will find the calculator useful to tell you what the Sine of a particular angle is.
In proper mathematics exams, you will not be allowed to use a fancy calculator that does graphing or, say, symbolic differentiation.
K
keith
"If you aim right, most of the angular momentum of the asteroid gets
transferred..."
And if you don't aim right, we all die.
We're all going to die anyway. If it's a three-cushion billiards shot
or life, which do you take? Personally, I don't worry about things that
are 5Bn years hence. My father had a perfect repsonse for those who said
that the next ice age was coming "soon" (this was 20 years before "global
warming" was all the rage); "Oh! I thought you said 500 years! You had me
worried there for a minute."
K
keith
Well it's true! If someone makes the slightest calculation error we'd
all be dead. I wouldn't trust someone to change the Earth's orbit with
an asteroid. I'm usually pretty optimistic, but that seems... too
risky.
If the alternative is...?
Luckily, I won't be around then so I won't have to worry about it. I
like the time period in which I live.
I think that's sorta the point...
~~SciGirl~~
Ok, I gotta get off now, my mom sets a limit to how late I can stay on
each day and it's 9:30 (I'm on ET). I'll check back in the morning.
~~SciGirl~~
"Throw away your calculator..."
We were each issued a calculator, and we were supposed to finish the
worksheet using the calculator. I finished, was bored, and graphed
random equations - tan x^2 came out really odd... anyway, I don't own
the graphing calculator so I can't throw it out. I see where you're
coming from though. My point is that I wasn't intending to find out
about the change in slope in a parabola; I was just amusing myself and
happened to notice it.
K
keith
If I cant escape the calculus, I'll have to learn the calculus. Darn.
Bad attitude. Do it right from the beginning and it's not all that
painful. Ace the hell outta algebra and geometry and you're well on your
way.
I've been given the name of a good calculus book by someone earlier, but
I need somewhere to learn precal first. I'm up to the challenge but I'll
probably try it over the summer. I won't have time now, and I really
doubt I'll understand much of it.
What they call "pre-calc" around here now we called "advanced algebra".
Pre-calc is really about limit theory. If that's not in there it's not
anything-calc. Study limits and geometry and calc won't be so bad.
I learned almost everything I know
about physics between September and now, but math doesn't come that
easily.
More work! ;-)
~~SciGirl~~
As I said, I need to leave now, so that was my last reply
K
keith
That's easy, they just don't have kinetic energy. Kinetic energy is
1/2mv^2 which, coupled with mass inflation, is why you would need
infinite energy to reach the speed of light. But it is not the only
energy in the ballgame.
So, you'e saying that photons striking an object don't impart any kenetic
energy to that object? Conservation of energy and all here...
K
keith
Exactly. It's the ease of cynicism. Since everything is doomed to
failure and life is a p.o.s., we can kick back and whine, sneer at
people who have hope, and laugh when things go wrong. Beats working!
"Hey you! Where's my check!"
By George, I think I've got it!
K
keith
256 KV; see abse.
I guess it's a good thing that TeeVees don't use relativistic voltages so
they work just fine on planet Earth. I hate it when mine has a
blue (state) shift.
John Larkin
I think you do. You are wise in ways that take "mellowing time" ;-)
Hey, Jim, kids nowadays are amazingly sophisticated. By kid knew stuff
when she was 10 that I didn't figure out til I was 40.
John
Y
YD
With your obvious mental talents, I'd aim a wee bit higher... unless
you want to be on the TV news hour ;-)
...Jim Thompson
Real meteorologists are a long way from any TV studio and they do all
kinds of physics, fluid dynamics, math, whatnot.
- YD.
