Hi guys I am new to the forum. I have Exide battery charger model # (70-100). I need to replace the 4 button diodes that is rated at 75amps 400 volts with a bridge rectifier. Can someone tell me which bridge rectifier I can use to replace these diodes with and how to connect it in the circuit of the charger? The button diode is press into a plate two in each row. The center pin of diodes is connected to a copper wire coming from the transformer one on each side.
