A schematic is something I don't have. So, please bear with me as I attempt a better explaination. The circuit that I am attempting to describe is for an outboard motor. The outboard uses a stator to produce AC current (alternator). The AC current then goes to a full wave bridge rectifier to produce rectified DC current to charge a 12 volt battery. The system is "non-regulated". Meaning there is no voltage regulator. The stator produces 180 to 200 volts of AC current. Some of this AC current is directed to the capacitor discharge ignition (CDI) and it's three coils which provide "spark" for the three cylinders via it's sparkplugs. The rest of the AC current that the stator produces is routed directly to the bridge rectifier to produce the "rectified DC current" in which the battery requires. Whatever DC or possibly AC current (I'm not sure which) the battery does not need is shorted to ground thru the rectifier. According to the repair manual for the outboard, voltage going to the battery should not exceed 14.5 volts. Any voltage readings above 14.5 volts with the motor running at or above a certain rpm the manual states is the cause of a faulty rectifier. With the motor running at the suggested rpm I get a reading of 17.5 volts. Going by what the manual says I am assuming I have a faulty rectifier. However, the out-of-range voltage reading of 17.5 volts may also be the cause of a faulty battery. For conversation sake though, I'd like to assume it is not. Electronic supply companies sell what I believe to be the very same type of rectifier for $2.50 vs. Outboard parts dealers want $60 plus dollars for a new rectifier. The manual states the rectifier has a amperage rating of 20 amps. However, the manual does not give the voltage rating for the rectifier. From what I am able to ascertain similar 20 amp rectifiers are offered with voltage ratings of: 50 volts, 100 volts, 200 volts, and 400 volts. What I would like to know is the voltage rating for a bridge rectifier based upon the input value of AC voltage of the circuit it is designed for. Or, is it based upon the value of rectified DC voltage the rectifier outputs regardless of the input AC voltage? Or, in otherwords do I need a rectifier that has a 200 volt rating or a 12-14.5 voltage rating. Or, perhaps a different voltage rating altogether?
