British Line and Netural Conventions?
I
Ira Rubinson
I live in the US and am re-wiring a 30 year old Logitek lapping machine
which was built in England. If I plug it in to a receptacle in the US, as it
is presently wired, then the limit switches carry 0V and the neutral is
fused. I don't think this is correct because a short to chassis in the limit
switch circuit will defeat the limit switch function. Are English wall
receptacles reversed with respect to US receptacles?
Thanks -Ira
Graham Holloway
it
limit
Thanks -Ira
English wall receptacles are completely different from US ones. Someone must
have fitted a US plug on the machine (wrongly) before you got it. Call in an
qualified electrician. Check the voltage settings as well and also see if
the change in frequency from 50Hz to 60Hz could give you a problem (motors,
etc.)
Graham H
Eeyore
In that era, live was red (for warning) and neutral was black. If you've wired
black (UK) to black (US) there's your problem.
Graham
John Larkin
Graham
The US convention is "white is life, black is death."
The other phases are red and blue. Quite patriotic wiring!
I got bit by a loose black wire yesterday, working on our old
hydraulic elevator. 120 nips a bit, but I bet 240 is a lot worse.
What colors do you use now?
John
Eeyore
The dull Euro-norm brown = live and blue = neutral. I think it came about by having
to be different to anything anyone used before !
The phase colours used to be red, blue and yellow. They've changed now to brown
something and something.
Graham
Gary Tait
Funny though, in automotive, black is usually ground, and I've seen people
used to one wireing sceme crew up the other, usually someome used to
automotive electrics mucking up AC wiring.
Eeyore
Just look at the colour coding on every multimeter's test leads.
The old UK wiring colours were the best.
Graham
Jeff L
Same colors here in Canada. Your low voltage 3 phase option is strange in
the USA (the 120V, 220V offset 3 phase thing). Here we have the more
standard 120V 208 3 Phase. We have a fairly odd 600V 3 phase that is often
coming into most commercial / industrial buildings with more then a 72 kVA
service. 480v seems more common around the world, and is used in the USA.
Europe uses a few odd voltages for 3 phase, like 380V.
One thing to note: white wires can be hot - eg the drop to a switch from a
light fixture.
If your dry, and not grounded overly well, you may not even feel 120V AC.
Wet is another story. I tried to remove the fresh spattered wet drywall
compound from around an outlet once when I was a kid - bad mistake it was
touching the hot terminal, and apparently all the acidicness of the compound
makes a good electrolyte.
Most of Europe seems to have the brown blue thing, with a green ground with
a yellow stripe.Very strange industrial plugs, and weird wire. I like the
covers that pop over the receptacle used for the huge 3 prong plugs - almost
impossible to electrocute yourself by sticking something in the plugs or
touching the prongs as you insert them. The plugs themselves are a little
too huge for my tastes, but old people must like them.
Japan seemed to have blue, brown and IIRC black for 3 phase, at lest that
was how some machines we have were wired. They have 100V over there instead
of 120V, and one half of the country is 60Hz, the other is 50Hz. I think one
of their 3 phase voltages is 200V.
John Larkin
Black ground is the electronic convention. Green is filament power,
red is B+. I forget the rest.
John
John Larkin
Hell, we have everything here. 120/208, split 240 stinger, all sorts
of stuff. 480 l-l for the bigger stuff. And electricians never leave
schematics behind.
John
Phil Hobbs
John
Yellow is 5V filament.
Cheers,
Phil Hobbs
Jeff L
Or the darker wire. I've seen green used on street bikes, along with black.
Black on many motorcycles (including off road - eg dirt and motocross) is
the ign kill wire. Older snowmobiles used black for the ign kill wire also.
Peter Bennett
On a used boat I just bought, apparently some DC wiring was done by an
AC electrician - he used Black/White pair wire, with white as ground
and black as +12 (but I think there's also some with black as ground -
lots of odd electrical things: there were two 12 volt batteries
apparently in parallel as the house bank - when I replaced them, I
found that the ground lead for one battery was not grounded! Must
have been that way since 2001, when the batteries were last replaced -
or perhaps much longer!)
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Paul Hovnanian P.E.
Hmm. Brown is ground in an old Porsche. Red is B+ and other (switched)
circuits are everything else.
Paul Hovnanian P.E.
380V is just the line to line voltage of a 220V line to neutral star
service. That's pretty standard (either a single phase or three phase
throughout Europe).
light fixture.
That's for electricians benefit to run a single NM (Romex) from the
light to the switch. They are stuck with one white wire for a hot. Safe
practice is to hook the white in the switch leg to the incoming hot from
the branch circuit (in the fixture) so when somebody sees a black and
white connected together, they'll stop and think (What the $%@&#! is
going on?). If you are pulling wire into conduit, white (gray) is for
neutral only.
H
Homer J Simpson
it
limit
In N America, the outlets are wired backwards; and black is 'hot'.
In Europe and many other countries, the left hand pin of a power outlet is
hot. Also black (or blue) is always 'cold' (neutral) and red, brown or
another color is hot.
H
Homer J Simpson
by having
Also ground/earth was green and is now green/yellow striped.
Michael A. Terrell
light fixture.
Some inspectors won't sign that off, without either phase tape or a
piece of colored heatshrink tubing on the switched white wire. Phase
tape is a lot cheaper than a coffin.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
H
Homer J Simpson
schematics behind.
In Europe, the UK, Australia, New Zealand and many other countries there is
one voltage in the range of 220 to 250 volts (actual value depends on the
country) single phase to neutral and a three phase supply based on that (*
square root of 3). The next voltage used is 11 kV 3 phase or similar used
for huge motors with special precautions.
In N America they use every voltage under the sun - hell they even used
multiple frequencies up until recently! It's very odd. You can even see two
switch boards in commercial buildings each with a different voltage.
H
Homer J Simpson
neutral only.
Code now outside of N America may require you to sleeve the wrong color wire
to the correct color, i.e. black to red.
