British Line and Netural Conventions?
I
Ira Rubinson
Thanks Homer.
Your explanation makes sense.
The unit works but I thought it was peculiar that neutral is fused and that
the limit switch circuit conducts neutral. When connected to a US 120VAC
wall receptacle, a blue wire on the machine connects to the right pin (hot)
on the receptacle and a brown wire on the machine connects to the left pin
(neutral) on the receptacle.
-Ira
Eeyore
Ira said:
Thanks Homer.
It's wrong !
Yes, it's miswired . Blue = neutral and Brown = live. You should correct the
miswiring really. Who did that ?
Graham
I
Ira Rubinson
This machine also has an AC gear motor with 2 white wires and a bluish-grey
curly wire. One of the white wires is disconnected but the motor turns. Do
you know the significance of the curly wire?
Thanks -Ira
H
Homer J Simpson
Thanks Homer.
that
(hot)
That's the new color code for Europe but Brown is hot and Blue is cold. You
need to switch them.
H
Homer J Simpson
bluish-grey
Is there a capacitor? The other white wire may be for a different voltage or
for reverse. I'd assume white is hot.
I
Ira Rubinson
Was it really re-wired? It has a typical AC receptacle of the type you see
on PCs and peripherals. It worked for many years. I was replacing the DC
motor controller when I encountered the peculiar wiring. Note that this unit
has 2 motors. One is AC for mixing the slurry and one is DC for the turn
table. I mention this because I posted another question concerning the curly
wire on the AC motor.
Eeyore
The 'IEC plug' presumably ?
http://www.bulgin.co.uk/Products/IEC_Connectors/iec_images/PX058-28_400px.jpg
These should be wired according to the standard which clearly states which is
live and which is neutral. The plug and receptacle usually have L N and E (for
Earth) clearly embossed in the plastic moulding.
Is the cable feeding it miswired perhaps ?
Graham
contrex
In Europe and many other countries, the left hand pin of a power outlet is
hot. Also black (or blue) is always 'cold' (neutral) and red, brown or
another color is hot.
(1) Europe is not a country
(2) In Great Britain, a country in Europe, the live pin is the bottom
right hand one (of three) in the outlet.
Adrian Tuddenham
John Larkin said:
Black ground is the electronic convention. Green is filament power,
red is B+. I forget the rest.
In the UK (possible Europe too), since the 1950s or even earlier, it has
been:
Red = H.T
Yellow = Anode
Purple = Screen grid (I think)
Green = Control grid
White = Cathode
Black = Chassis
Grey = Negative bias or feedback or A.G.C.
Brown twisted = heaters (well tucked into the corner of the chassis)
Yellow & black twisted = Loudspeaker
Red & black twisted = Mains
Blue & white twisted = 600 ohm balanced line
Michael A. Terrell
Thanks -Ira
You should be asking these questions on
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
N
Nick Mueller
Michael said:
You should be asking these questions on news:rec.crafts.metalworking
At least in Germany, black is hot (death = black), blue is neutral ("cold").
PE is yellow/green.
Red is *very* old and no longer used. And I don't remember how it was.
With 3 phases, brown is hot too (1 brown, 2 black, 1 blue + PE).
Nick
Gary Tait
correct the miswiring really. Who did that ?
Graham
You have to know that IEC is "backwards" compared to a US recepticle.
Looking at an IEC socket with earth down, hot is to the left, and Neutral
to the right.
Eeyore
to the right.
I don't care who thinks it's backwards.
There's a standard for wiring IEC plugs and sockets and the letters L, N and E
are embossed in the plastic. There's no excuse for mistakes.
Graham
H
Homer J Simpson
Did I say it was? The United States is a collection of states.
It's just upside down from normal.
Gibbo
Everyone else's is upside down :)
John Larkin
In N America, the outlets are wired backwards; and black is 'hot'.
Left/right? In San Francisco, sockets in commercial buildings are
wired with the ground pin up, and for residential it's down.
John
Chuck
John
The NEC doesn't specify whether it
should be up or down. That is left to
local codes, I think.
Chuck
