Broadband transformer center tap?
H
Hammy
I want to use a transformer on the output of a DAC on a AD9834 DDS IC.
Heres is a picture of using a transformer on the output of one of
Analog devices DDS IC's.
http://i48.tinypic.com/25gvw5t.png
If I want to transform from 200ohms (which is what the DAC needs to
stay in compliance) to 50 ohms output Z. Is this correct;
Turns ratio for transforming 200 -> 50
Square root of 200/50 = 2
Primary inductance for 3db at 10kHz is 159uH. I calculated this based
on examples from application notes coil craft and here.
http://www.electronics-tutorials.com/basics/wide-band-rf-transformers.htm
I'm after as low a frequency I can get to at least 10 Mhz using the
same toroid as this guy. (35T0501-10H)
10 KHz to 85 MHz. A SIMPLE BROADBAND TRANSFORMER.
http://www.cliftonlaboratories.com/easy_broadband_transformer.htm
Now my question about the center tap primary. My calculated primary
inductance is 159uH as already mentioned for correct transformation do
I put two 159uH windings on the primary or just one 159uH winding on
the primary and tap it at the mid point 79.5 uH?
Andrew Holme
Inductance of a solenoid is proportional to number of turns squared.
Double the number of turns and you get four times the inductance.
If they are closely coupled, two 40 uH windings in series make a
centre-tapped 160 uH winding.
The impedance seen across a centre-tapped transformer winding is four times
the impedance seen between the centre-tap and either end.
