Broken antenna on RC car
Mike S.
I have a 14 y/o RC car that has a broken antenna on the remote. Is
there a way to fix that? The car won't work without it. The antenna is
like the ones that are on boomboxes. There was a small piece of metal
that kept it attached to the remote and the piece broke off.
I tried attaching wire to the remote and the car barely worked. Is
there a specific kind of wire I need?
I could probably buy a better car than this one but I don't like
throwing things away if they can be fixed, unless it costs too much to
fix it.
JANA
Antennas are tuned. Go to where you bought your remote car and see if they
can supply an original part.
JANA
_____
fix it.
W
William Sommerwerck
remote car and see if they can supply an original part.
Forgive me, but I find a lot of your postings misleading or non-factual.
Antennas are not, generally, "tuned". If tuning is required, it's usually
performed with a loading coil in the body of the transmitter. The only
consumer product I've ever seen with a loading coil in the antenna itself
was a Concord CB transceiver of 40 years ago. (The intent was to improve
radiation by moving the coild to the middle of the antenna.)
If the antenna is the correct length, it will radiate efficiently. You don't
need an OEM antenna.
jakdedert
You both are 'sort of' right, it would seem to me. Of course there are
inductors in consumer electronics. Whether you call them loading coils
or something else, in every transmitter I've encountered, there was an
inductor in the signal output path which tuned the original length of
antenna to approximate the expected load of the antenna.
That said, getting the correct length antenna (or a longer telescoping
one, but not fully extending it) is a pretty trivial matter...as long as
that length can be determined.
jak
Jamie
jak
Ah, Just cut up a hanger and stick it in there! :)))
"I'd rather have a bottle in front of me than a frontal lobotomy"
"Daily Thought:
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT
THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
http://webpages.charter.net/jamie_5"
Michael Kennedy
"Daily Thought:
Well if it is in the 44mhz range like most cheap rc stuff is pretty much
anything attached to it will recieve a signal sufficient to make it work.
Sure length will make a difference in how well it works, but you may be able
to get close enough by guessing.
W
William Sommerwerck
If it's in the 47 MHz range like most cheap R/C stuff is,
pretty much anything attached to it will recieve [sic] a
signal sufficient to make it work. Sure, length will make
And inasmuch as the OP has the original antenna, there's no guessing about
the "correct" length.
In short, you don't need the "original" antenna.
Michael A. Terrell
Why don't you 'Stick it', Jamie? You aren't the least bit funny, and
a cut off hanger stuck into the remote could cause a severe injury, or
death.
Piano wire, with a closed loop on the end makes a nice antenna,
becasue it won't catch on anything, and is springy enough to resist
damage.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
radiosrfun
death.
damage.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Though a Hanger "could" work in a pinch, I agree with Michael. Most of those
RC type antennas are a thin metal which has some play to it. The regular RC
antennas are thinner and thus "lighter" than a "Hanger". It would not drag
the RC down - where a "Hanger" might. Depending on the size of the RC unit,
the "hanger" could make it top heavy! If the RC goes under an item, the
hanger - if not budging "could" cause internal damage when the shock hits
the base. The "RC type" would tend to give and perhaps - "no" damage. I
don't deal with RC stuff enough to get into all "suppliers" but it seems
someone should sell the antennas - maybe a hobby shop. OR get some wire like
Michael suggested and use it - some of the "home remodeling" type stores
seem to sell a variety of wire gauges. Surely there is some out there
somewhere for you to find. Go to a flea market or Hamfest - you may find
some "junk" stuff there from which to pull an antenna from. I see that kind
of stuff all the time.
jakdedert
Uh...okay. I'd agree with all the above, except the OP said "remote"
which I took to mean the transmitter. I'm still convinced that's what
he meant. If so little of the above actually applies.
That said, 'kids do the darndest things...' so having anything sharp
sticking out 'anywhere' could be a hazard; but I think when Jamie
recommended a coathanger he had tongue firmly in cheek (note the double
smileys).
As a kid, I *always* broke off the antennas on the cheap
three-transistor walkie-talkies I got...and used a chunk of 12 gauge
solid copper wire stuck down the stub as a replacement...worked passably
well, despite not being 'tuned' properly.
This thread got contentious when JANA apparently advised against trying
a substitute, based on some vague information about tuning. Then
William jumped in with a bunch of stuff not in the OP--or the
response--about loading coils, and went OT from there.
One final note: in the OP, it was mentioned that he stuck a piece of
wire in there, and it 'didn't work'. I think he might look into the
possibility that some connection was broken inside the unit. Wire
'should' have worked, as long as it was connected solidly, nearly the
correct length--and solid, not stranded.
This is a 14 year old TOY, in all probability...nothing to get worked up
over.
jak
radiosrfun
which I took to mean the transmitter. I'm still convinced that's what he
smileys).
As a kid, I *always* broke off the antennas on the cheap three-transistor
walkie-talkies I got...and used a chunk of 12 gauge solid copper wire
stuck down the stub as a replacement...worked passably well, despite not
This thread got contentious when JANA apparently advised against trying a
substitute, based on some vague information about tuning. Then William
jumped in with a bunch of stuff not in the OP--or the response--about
One final note: in the OP, it was mentioned that he stuck a piece of wire
over.
jak
I've lost track of the OPs intent. Still - a "hanger" though possible -
would make the thing a bit eh - heavy. "I" am not getting all bent over it -
just adding an extra opinion to the thread. What the OP ends up doing - is
their thing. If I ask a question, I take in all advice then go from there.
Thats how it works. AND yes - some suggestions "may" seem a tad safer or
unsafe than others. Not every suggestion will work for every one. But it is
nice to see - the OP IS getting some replies.
W
William Sommerwerck
against trying a substitute, based on some vague information
about tuning. Then William jumped in with a bunch of stuff not
in the OP -- or the response -- about loading coils, and went
OT from there.
I was trying to _explain_ why what JANA said was (generally) incorrect,
rather than simply gainsaying him. JANA got "off-topic" by providing
incorrect/invalid information.
Absolutely!
Seconding this, most high-end RC transmitters will transmit on a
variety of frequencies within a specific range, changed by crystal.
Each frequency comes with a recommended antenna length for best
performance (again this is specific to the manufacturer). Those of us
who run R/C submarines with FM transmitters are acutely sensitive to
this. The proper antenna length can make a difference of several feet
of depth, although it has less of a perceptable effect on distance. I
cannot write to the effects of antenna length on an AM transmitter. I
do have a couple of AM R/C units, but they are "just toys" and so are
never run at any great distance from the transmitter.
Peter Wieck
Wyncote, PA
W
William Sommerwerck
The difference in frequency is less than 5% -- probably less than 2%. That
is not a major difference in antenna length.
Inches, anyway. I do notice that when I trim the antenna "correctly",
I will get about another foot of depth before the "No-Signal" blow-
ballast (Sub-Saver) relay kicks in. There are several of us on our bit
of creek, so we are acutely sensitive to frequency and try to be
several steps apart, at least.
I had to change out the factory motor in the latest sub for one with
more torque and speed, which, in turn required a different propellor
(but same diameter) to reduce cavitation at the higher RPM. Going
downstream is no problem. Going upstream requires a bit more oomph
than is typical of a submarine operating at "scale" speeds. The creek
is about 40' wide and something around 6' deep in the channel directly
in front of our summer house, and crystal-clear so ideal for the
purpose - except for the current.
Jamie
death.
damage.
Why don't you go stick your head in a tub of water for
a while. You have absolutely no personally what so ever!
I can picture you sitting in the back corner of a party doing
nothing but badgering every one that's enjoying them self's.
You must be a real joy at a party! I bet they try to leave you
home!.
My bottom footer message fits you well.
"Daily Thought:
Michael A. Terrell
Why don't you practice what you 'screch', and learn proper engliosh,
while you';re at it? You calim to be an engineer, ytet you appear to be
about 15 years old.
home!.
"Daily Thought:
Come on down to Florida any time you think that you're man enough to
push me down the stairs, slinky boy.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Don Bowey
about 15 years old.
Give Jamie a break...... He does fairly well for a guy who didn't get
beyond the 5th grade.
W
William Sommerwerck
When I visited a friend in Texas some years back with my R/C submarine, we
managed to get it to dive (in a swimming pool) to a point well beyond the
maximum spec'd radio range, and it got stuck (even though the "descent
propeller" had shut off), because it didn't have enough bouyancy to rise
from that depth!
