broken Toshiba remote control?
H
happy150
I have a television model number CZ27T31. Yesterday I tried to turn on the
television using the remote control but it would not turn on. By pressing
the button on the television it turned on and off. With the same remote
control I am able to turn on and off the Toshiba VCR. I tried to use
another Toshiba remote control used for another VCR and it did not work. I
pulled out the batteries from the remote and disconnected the television
from the electrical outlet. Later on that day I was able to use the remote
to turn on the television but today I am not able to. I would appreciate
information to fixed the problem?
Thank you,
Tony
[email protected]
Textool
As the other post mentioned, change the batteries because it's possible the TV
and VCR do not have equal sensitivity to the remote.
If this doesn't help then..... TV sets can get very dusty inside due to the
high voltage attracting the dust and the heat that causes air to constantly
flow through the cabinet. It's possible that the Infra-Red detector is blocked
by dust and dirt build up inside of the cabinet and it can't a strong enough
signal from the remote. VCR's are much less prone to this kind of problem. Have
a professional clean the thing out and/or diagnose the problem.
David H
<< have a television model number CZ27T31. Yesterday I tried to turn on the
Thank you,
Tony
[email protected]
