I have read most of this thread in hopes of confirming my supposition
regarding s electrical problem with our cooking range. Seems like
most everyone here is much smarter than me. Please allow me to ask
this stupid question. The indications are that the timer/controler/
clock/ on the range goes into intermittent error mode after a rain
storm, but NOT LIGHTING. If there is a long period of no rain then it
works fine. Once there is rain, it goes back to intermittent error.
The error is anything from beeping, to no oven operations to timer
not working. We replaced the module with a new one and the same error
code showed up, in fact it was worse, luckily it was returnable. We
put the original module back in place and the error code disappeared
after a period of dry spells. My assumption is that the electrical
transformer or feed to the residence is not providing a constant
voltage. I assume the control module on the stove/range is voltage
sensitive. I started a search for voltage monitoring devices which
will record the voltage over a period of time, either digitally or
analog on a graph. So far, no luck in finding such a device.
The transformer is at ground level and supplies two homes. The feed
is underground to and from the transformer.
My questions are several:
1. Will low or high voltage cause the problem of a control module
intermittently showing error codes.
2. Where can I get an inexpensive monitoring device to record the
voltage over a period time.
3. Is is possible that the outside transformer is getting wet and
causing the problem?
4. Is it possible that the buried high voltage feed to the
transformer is fluctuating and can it be monitored?
4. What words can I use to tell the electric company they need to
verify the voltage to our house is constant over a period of time.
Thanks, Mike
Anything is possible. No other malfunctions? When it rains?
I have found my electric company is more than willing to come out and
deal with complaints. Never had any myself, but a few neighbors did
and with my advice did call the company. In both cases they did solve
a problem - transformer ground missing causing buzzing in a stereo,
and transformer lightning arrestor laying on the ground in pieces.
Try them first. You shouldn't need to spend a lot of time on it. It
could still be something in your house, so keep an open mind.
Service entrance getting rain into the meter box, loose connection on
the circuit breaker to the range . . . AFTER a rain event (does that
imply that it takes some time? - like water trickling down into
something?) Coincidence?
Lotta weird stuff can happen when 120 VAC comes into contact with wet
wood - so keep an open mind. AND I'd check the ground on the range to
make sure it does ground. If it is a three wire range - ground shares
current with 120 VAC gizmos like lights and controllers - a newer
(code) 4 wire range has a dedicated ground and not a neutral/ground
combination. Either arrangement can cause problems.
