Can I replace a brown ceramic capacitor with blue ceramic?
Caveman
Dec 3, 2022
4
I have a blue and yellow in stoc and thought they are same as brown capacitor but not sure after reading. Can I replace the brown with blue?97BCA327-7C34-4893-9B65-D6A0611FEF12.jpeg
bertus
3,874
No, the code 560 stands for 56 pF and 561 stands for 560 pF.
Have a look at this page for capacitor codes:
Bertus
Minder
Apr 24, 2015
3,561
Yes it should be OK, unless you think it might clash with the other colours! :p
And Bertus pointed out the error .
dragon
Oct 31, 2022
248
going higher in capacitance sometimes works, but going lower probably doesnt.
willsonwanda
Dec 13, 2022
5
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
That blue one appears to be rated for four kilo-volts, although I don't see how it could reliably hold off that much voltage given the small distance between its two leads. The other two capacitors surely are not rated for such high voltage. Could the blue one and the yellow one be dipped mica capacitors, while the brown one is clearly a low-valued ceramic capacitor? There could be a problem with temperature coefficient of capacitance, depending on the circuit. Such low capacitance values are usually associated with radio-frequency tuned circuits or used as high-frequency by-pass capacitors, often in parallel with a larger-valued electrolytic capacitor. As others have pointed out, the blue one is 560 pF while the other two are only 56 pF each.
