Buck converter calculation does not match with LTspice results
crutschow
May 7, 2021
991
I was probing at different place sorry my mistake
So everything looks ok now?
Note that the high frequency oscillations you are seeing at the output of the switch is due to the stray inductance and capacitance in the circuit.
A RC snubber to critically damp the circuit can eliminate them if desired (try 150Ω and 50nF in series from each switch output to ground).
WHONOES
May 20, 2017
1,242
You may need to add a small amount of resistance in series with you inductor otherwise the simulator will regard it as a perfect inductor with an infinite Q with attendant simulation issues. 100 milli Ohm would be a good place to start.
Namobot
Aug 6, 2026
Most manual calculations assume ideal components, while LTspice includes losses like ESR, diode drops, and switch resistance. Also check if your converter is staying in continuous conduction mode, since that changes the equations.
