Burnt transistor/resistance
MrTAP
Dec 2, 2025
Good Evening,
I have a dehumidifier that blew up the transistor and the resistance. Does anyone know what kind of transistor is? i´m having a really hard time find out which is the correct value to replace it.
Can anyone help ? thank you so much in advance
Delta Prime
Jul 29, 2020
2,989
Clean off the The transistor the smoke residue is masking the numbers
baldguyfromblackpool
Dec 18, 2025
27
Just some Googles,
Maybe B&Q / Kingfisher / Blyss / Challenge, Dehumidifier D002A ?
Found a couple of similar boards, but they're not quite the same
https://shorturl.at/SZo3u
https://shorturl.at/K6bWo
Broadly similar power boards in D003A, D015B, D016B ?
Unfortunately not much help to give you the correct values and part numbers for your exact pcb
Delta Prime
Jul 29, 2020
2,989
Can you discern any numbers on that transistor?
where is the resistor?
Also, can you take a photo of where you de-sordered that transistor and or resistor both sides of the printed circuit board please.
