Caddilac Deville LED brake/tail lights, how did they do it?
JazzMan
I was looking at the above this evening, all of the LEDs
were of equal brightness and the tail light portion did
not dim when the brake/turn portion flashed. There looked
to be probably more than a hundred LEDs per side, how do
they control and maintain brightness? Is each LED individually
trimmed and controlled current-wise?
The lights are a bit too expensive to just go buy one to
disassemble, and I doubt GM would email me the schematic
and design particulars, so I thought I'd pose the question
here where all the smart people seem to hang out. :)
JazzMan
Please reply to jsavage"at"airmail.net.
Curse those darned bulk e-mailers!
"Rats and roaches live by competition under the laws of
supply and demand. It is the privilege of human beings to
live under the laws of justice and mercy." - Wendell Berry
JazzMan
The Cadillacs I've seen around LA sure don't have uniform brightness on
the LEDs. That instant turn on/off is creepy to look at IMHO. Couldn't
they add some capacitors to sloppy up the on/off time?
The only automotive LED assembly I saw was the center brake light on a
VW Jetta. It had 3 or 4 strings of LEDs (12 total LEDs) with a resistor
for each string and 1 series 1N400x for reverse polarity protection. It
ran a total of 280 mA and was blindingly bright on the bench. The
series diode had failed but still read a normal diode drop with a Fluke
8060 though the forward voltage drop was several volts under load.
GG
David L. Jones
Probably just multiple constant current regulators driving a series
string of LEDs. Doubt it would be any fancier than that.
They might pay a bit more to get the primo LEDs that are more tightly
matched in brightness.
Dave :)
Jasen Betts
Is each LED individually trimmed and controlled current-wise?
There's a thing called Kirchoff's law that says that devices
connected in series will all experience the same current.
they could be powering all those LEDs in series using a voltage
booster or they could be doing it in series groups of 4 from 12V
Bye.
Jasen
