Mook Johnson
- Jan 1, 1970
- 0
http://www.st.com/stonline/books/pdf/docs/9572.pdf
I asked a broader question before and it must have been too much.
Here is a simpler version and more to the point of what I'm after.
Using the above MOSFET in a switching application with the following
specifications.
Configuration: half bridge
Bus Voltage: 500V
peak flat top current 1.5A (start of ramp on step is 1A, Anti-parallel diode
freewheels the inductaive load)
May place an external diode if the internal diode causes too much
dissipation.
switching freq = 10kHz 90% duty cycle
I can figure out the losses due to the Rds_on but I'd like to get an
estimate of the switching losses.
The FETs will be driven with a TC4427 1.5A fet driver with a small ~5 ohm
resistor to damp the resonant tank between the pin an trace inductance and
the gate capacitance.
Can someone help me with this please?
specifications.
Bus Voltage: 500V
dissipation.
