How to calculate on/off time with 2 Capacitors
burrism
Oct 15, 2024
14
Good morning. I hope everyone had a pleasant thanksgiving. I am trying to build a flasher circuit that I can adjust the on and off times. I found the attached circuit and tried it but the times are too long (I am looking for a few seconds, like 0-10 on each vice double or triple digit times). The only formula I can find to help calculate the on and off times is based on a single resistor and capacitor on the threshold and discharge pins (T=1.1xR1xC1). Is there something out there I can use to calculate the appropriate on and off variable resistors ???
TIA
  • 555.pdf
Delta Prime
Jul 29, 2020
2,995
Hello!
Nice to talk to you again.
So you need a free running ,A stable, multi vibrator?(flasher circuit.)
The equation you posted is for a Monostable,one shot.(just one flash or pulse.)
(T=1.1xR1xC1).
In your schematic, you have two Zener diodes designated as D1 and D2. Are those two LEDs you wish to have flash for maybe one to 10 seconds Back-and-forth, off & on?
burrism
Oct 15, 2024
14
Hello again Delta Prime! So the Diodes are just in there, not sure why they are there but they are not LEDs. The schematic is not my design, I saw it at the video associated worked like I wanted it to, so I copied it but the resistor and capacitor values are off. :( My ultimate goal is to replace a vehicle turn signal relay that blinks too fast (rapidly) for my sequential LED application. I would like to control the on and off times so I can ensure my LED sequencer makes it through the whole sequence before it starts over. I would also like to have the potential of using this for other applications as well otherwise I could just make a monostable timer with set on and off times using the formula I had.
Delta Prime
Jul 29, 2020
2,995
No problemo.
Take a look at this online 555 timer calculator, courtesy of; the one & only… @bertus
danadak
Feb 19, 2021
1,103
Could always do this with ATTINY85 and simple code.
The above is mBlock, you code by drag and drop and config blocks, and it generates
Arduino code to use.
Regards, Dana.
